08-08-2008, 04:21 PM #1
Looking for any advice or information....
My friend and I were wondering if was possible was to cut a fridge of inner-workings and transplant them. We want to make a kegerator but want to make a custom one out of wood. I was thinking about getting an old fridge and taking the motor out and some how fixing the whole set up in side a custom made wooded insulated box. Any ideas ?
08-08-2008, 04:31 PM #2
Re: Looking for any advice or information....
VERY carefully and lots and lots of ptience
did it myself once,and believe me,patience is the key.
Ice
09-08-2008, 12:39 AM #3
10-08-2008, 07:01 AM #4
The single temperature refrigerators built in the late 40's into the 50's were of a design that you could pull apart.
The refrigeration unit was fully assembled, the evaporator box was installed through a hole in the back of the cabinet, then a insulated panel was fitted to cover the hole.
In your case all you would have to do is undo the rear panel and pull the guts out.
10-08-2008, 01:02 PM #5
i remember doing this kind of job whit the camper refrigerators,the absorption units. if the unit was broken you could by a new set and build it in yourself.the system was to cut out the back panel on the place were the evap is situated,and foam it up afterwords when you were done.toke me about 4 hours to do this kind of job. now the have so many promos you just by a new one.
Ice
13-08-2008, 08:19 PM #6
What about finding an apartment size fridge that fits a beer keg and just building a cabinet around it?
OC
13-08-2008, 08:41 PM #7
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
Hot water is alredy invented!
Check this site.
14-08-2008, 02:05 AM #8
we want to make it as small as possible, we are trying to fit it under our bar
14-08-2008, 04:22 PM #9
pls i need ur assistance bcos i am trying to design a new size of machine which could finish within 2to3 hrs but a dry system.
14-08-2008, 04:28 PM #10
also can u send me a refrigeration site 4 futher knowledge
15-08-2008, 08:25 AM #11
Seeking Advice on Retraining for AC&R
By Stu76 in forum TrainingReplies: 5Last Post: 23-08-2008, 10:52 AM -
Career advice please.
By james 100 in forum Chit Chat & Service StoriesReplies: 14Last Post: 13-09-2007, 06:37 PM -
Defrost information needed
By church2k in forum System OptimizationReplies: 6Last Post: 04-06-2007, 04:04 AM -
auxiliary components information
By mohamed khamis in forum Tools and CalculatorsReplies: 2Last Post: 27-04-2006, 01:20 PM -
Information on Hussmann enviropacks
By tonydeith in forum Supermarket RefrigerationReplies: 0Last Post: 25-04-2006, 01:22 PM
