    selbstar81's Avatar
    selbstar81 Guest
    Blast Freezer Cooling / Heating Times
    Hi there,
    First post so go easy on me.
    I keep neing being asked by white wall contractors for max cooling / heating times to cool / heat a room in order for them to size the pressure relief valves to gaurd against walls collapsing / doors not easily opened. Now I thought I would be able to work this out quite simply but am really struggling to put an equation together. Has anyone got some form of equation that might help me here or any suggestions? It would be greatly appreciated.
    11,025
    Re: Blast Freezer Cooling / Heating Times
    How is the time involved related to air pressure generation within the room?
    Surely your blast freezer is recirculating the air within the space.
    India
    688
    Yes time has an important role. The faster the cooling faster is the vacuum creation. I have few charts on this. But send me a PMS then only I can send the file. I have exhausted all the slots for uploading.
    Feb 2008
    Las Vegas, NV
    67
    330
    Interesting question. I did some searching and it seems each manufacturer has different specs. Here's a link to Kason's site which list how to size their pressure relief vents.
    http://www.kasonind.com/images/stori...och_06.web.pdf
    selbstar81's Avatar
    selbstar81 Guest
    How do I send you a PMS?
    11,025
    Quote Originally Posted by selbstar81 View Post
    If you click on the members name you will see the option to send a PM.
    nevgee's Avatar
    nevgee is offline Veteran Poster I am starting to push the Mods: of RE
    May 2006
    Yorkshire
    72
    417
    The problem occurs when the bfreezer door is closed and the freezing process is started. The warm air within the chamber cools very quickly causing a negative pressure within the chamber. If a releif device is not built into the structure of the chamber then a risk of collapse can occur. On smaller chambers usually the doors are pulled tight on their seals and become difficult to open, on large stores the whole structure can collapse.
    Fermod used to make pressure reliefs and would offer a selection proceedure.
    We used to cut a hole into the roof of the chamber to allow for pressure relieve ... this might not be acceptable today.
    Reality is an elusion created by alcohol deficiency. Quaff and enjoy. [Yorkshire, UK]
  1. underfloor heating and cooling
    Last Post: 11-12-2009, 12:22 PM
  2. Trolley freezer & blast freezer
    By smpsmp45 in forum NH3
    Last Post: 25-08-2007, 07:29 AM
  3. Blast Freezer
    By w.l.ong in forum Industrial
    Last Post: 16-12-2006, 10:34 AM
  4. Heating / Cooling Control
    By walden in forum Electrical
    Last Post: 16-04-2006, 01:20 PM
  5. Blast Freezer Questions
    By rickmor in forum Industrial
    Last Post: 11-04-2006, 08:15 PM
