Results 1 to 2 of 2
    Oct 2004
    65
    Hot gas bypass psi setting on a R-404a system
    Hello fello fans of refrigeration,
    Is there a rule of thumb for setting the psi of this Emerson CPHE valve.
    Evap temp will be around 0F.
    It is an ON/OFF solenoid system and the room setpoint is 8F.
    Liquid injection is present and the crankcase pressure regulator is current set at 45psi.
    Thanks for the help, Joe.
    May 2008
    66
    802
    Re: Hot gas bypass psi setting on a R-404a system
    hope you find wat you are looking for.
    www.ecopeland.com/Literature/Alco/DE_EN_CPHE_65008.pdf
    Ice
  1. Daikin fault codes
    By Chris2005 in forum Air Conditioning
    Last Post: 21-03-2012, 10:09 PM
  2. Which system is better R 404A or R 717?
    By smpsmp45 in forum Refrigerants
    Last Post: 25-08-2011, 01:42 AM
  3. Leak Testing?
    By Thana in forum Trouble Shooting
    Last Post: 31-08-2010, 02:57 PM
  4. old system with hot gas bypass. help!
    By joapysoe in forum Trouble Shooting
    Last Post: 20-01-2008, 11:58 PM
Tags for this Thread
