08-08-2008, 02:32 PM #1
Hot gas bypass psi setting on a R-404a system
Hello fello fans of refrigeration,
Is there a rule of thumb for setting the psi of this Emerson CPHE valve.
Evap temp will be around 0F.
It is an ON/OFF solenoid system and the room setpoint is 8F.
Liquid injection is present and the crankcase pressure regulator is current set at 45psi.
Thanks for the help, Joe.
08-08-2008, 04:47 PM #2
Re: Hot gas bypass psi setting on a R-404a system
hope you find wat you are looking for.
www.ecopeland.com/Literature/Alco/DE_EN_CPHE_65008.pdf
Ice
Daikin fault codes
Which system is better R 404A or R 717?
By smpsmp45 in forum RefrigerantsReplies: 36Last Post: 25-08-2011, 01:42 AM -
Leak Testing?
By Thana in forum Trouble ShootingReplies: 36Last Post: 31-08-2010, 02:57 PM -
old system with hot gas bypass. help!
By joapysoe in forum Trouble ShootingReplies: 8Last Post: 20-01-2008, 11:58 PM
