Results 1 to 1 of 1
06-08-2008, 12:52 PM #1
How to calculate the length of evaporator coil
Dear friends,
Can any one guide me, how to calculate the optimum length of the evaporator coil for my machine.
The unit has a 755 BTU CBP compressor with evaporator inlet temperature of -10 deg Celcius. The ice bank temperature would be -3 deg Celcius after full ice formation. The evaporator coil is of 6 mm outer dia/ 5mm inner dia SS material. I tried calculation, but could not find correct information/knowledge source for this kind of evaporator coil.
Please help
Thanks and Regards
Giridhar
Condenser Length Problem
By tanveerkuet in forum Technical SpeculationsReplies: 5Last Post: 01-02-2008, 01:05 PM -
Equivalent length for fittings
By harsen in forum Technical SpeculationsReplies: 12Last Post: 11-04-2007, 05:13 AM -
Help to calculate Heat Exchancger
By Carode in forum FundamentalsReplies: 1Last Post: 17-12-2003, 11:57 PM -
how to calculate the length of evapurator
By heanboon in forum FundamentalsReplies: 2Last Post: 17-10-2001, 12:36 PM
