    agfb96's Avatar
    agfb96 Guest
    restricted system
    Hi guy, I have a problem with icecream freezer just hermetic. suction pressure down to 0, compressor too hot, amps high by 1 amps. when I turn off liquid line become cold suction press only 30psi. do I have a restricted system?
    Sep 2003
    ISRAEL
    72
    4,248
    Re: restricted system
    Yes.
    If it runs on 134a, cup tube.
    Replace drier.
    agfb96's Avatar
    agfb96 Guest
    Its 404, but I purge the system and change the drier, its all good now. thanks!
  1. Daikin fault codes
    By Chris2005 in forum Air Conditioning
    Last Post: 21-03-2012, 10:09 PM
  2. Leak Testing?
    By Thana in forum Trouble Shooting
    Last Post: 31-08-2010, 02:57 PM
  3. System Burn Out Troubleshooting
    By altaf22m in forum Technical Discussions
    Last Post: 07-05-2010, 09:24 AM
  4. Replies: 19
    Last Post: 15-04-2008, 07:03 PM
