Results 1 to 8 of 8
    Apr 2008
    Tehran
    42
    10
    R134a Replacement
    What is the best and optimal Refrigerant for replacing R134a?
    Apr 2002
    scotland
    114
    23
    Re: R134a Replacement
    why are you replacing it?
    you could use r409a which is an R12 drop-in, it will run on snythetic and mineral oils
    Apr 2008
    Tehran
    42
    10
    What about R-407a?
    can i replace r134a with r407a?
    Don't use R409 it contains R22 which is on its way out.
    Why do you want to repace R134a?
    Mar 2006
    Merate (LC) - Italy
    2,549
    No reason to replace R134a. What for?
    WAF's Avatar
    WAF Guest
    Would go with r413a just incase you come across old r12 systems.
    Dec 2001
    137
    23
    Best match is R413A which can be used long term. is designed for mineral oil but works well with polyolesters etc and has fairly similar characteristics but with a generally lower charge weight.Your local isceon supplier can give you the full data the trade nane is isceom M049
    Brit
    Oct 2003
    brazil
    59
    43
    hi guy here in brazil im use r413a in replade r134 good luck
  1. R507 in an R134a compressor: any danger?
    Last Post: 21-12-2009, 12:44 AM
  2. R134a replacement help
    By Bill in forum Fundamentals
    Last Post: 27-02-2006, 05:18 PM
  3. Pressure Transmitter R134a Setpoints
    By cooltrain in forum Technical Speculations
    Last Post: 28-02-2005, 09:05 AM
  4. Replies: 5
    Last Post: 01-03-2004, 09:59 PM
  5. R507 in an R134a compressor: system design
    Last Post: 01-05-2003, 09:25 AM
