    Dunedin397's Avatar
    Dunedin397 Guest
    Zanussi Electrolux Fridge\Freezer Leak
    Hello Everyone,
    I've a Zanussi Electrolux fridge\freezer that appears to be leaking water from the freezer section. It seems to be coming from what appears to be a hood (almost looking like a cooker hood) at the back of the freezer, down along the floor and out of the door on the left.
    I cleaned the freezer out and the flow seemed to increase the longer the door was open (and presumably warming up). I've turned the min\max control close to max and it seems to have stopped.
    Could anyone tell me what the problem could be?
    Thank you,
    Dunedin397
    Jul 2007
    Australia
    1,845
    Re: Zanussi Electrolux Fridge\Freezer Leak
    blocked drain.
    Could be a failure of the drain pan heater, or just stuff blocking it.
    There will be a ton of ice in the drain which will take a long time to defrost. After that, it's just a matter of clearing the drain and blowing through, also checking the drain pan heater works.
    Your main heater and defrost cycle works (otherwise you wouldn't get any water. So it's not a big problem, it's just going to take some time, or stripping down, defrosting and checking resistance of the heater.
    Aug 2008
    i thing paul gave u the answer .
    king
  1. Leak Testing?
    By Thana in forum Trouble Shooting
    Last Post: 31-08-2010, 02:57 PM
  2. Leak detectors
    By Temprite in forum Tools and Calculators
    Last Post: 18-08-2010, 04:15 PM
  3. Evasive gas leak
    By Feeze in forum Technical Discussions
    Last Post: 18-08-2008, 07:22 AM
  4. Gas Leak!
    By Chunk in forum Chit Chat & Service Stories
    Last Post: 31-03-2008, 06:48 PM
  5. Help!!! Shell and Tube Evap Leak
    By tommy Gun in forum Trouble Shooting
    Last Post: 22-07-2007, 12:45 PM
