    smokemare's Avatar
    smokemare Guest
    Carrier Fault Code 42VQV080
    I'm having trouble solving a fault code for an Israel built Carrier 42VQV080 cassette. It's one of the larger cassettes mounted low level.
    The orange light flashes once, then the green light flashes four times. I've trawled the carrier documentation loca
    11,025
    Re: Carrier Fault Code 42VQV080
    It could be an outdoor coil sensor.
    Try here and select any of the cassette models...
    http://www.uk.carrier.com/sitemap.htm
    The fault codes appear to be the same whichever model it is.
    smokemare's Avatar
    smokemare Guest
    If that is the case - can it be fixed easily? It is expensive? A customer wants some air conditioners moved from one office to another, I can't pump this one down though as this area comes up before the compressor kicks in. Obviously I don't want to remove it from one office until I'm 110% sure it's working properly.
    I can't seem to find the code for one orange four green flashes, HELP !
    11,025
    Can you not manually operate the compressor to pump the system down?
    If all else fails try contacting Carrier.
    smokemare's Avatar
    smokemare Guest
    Hmmm, possibly - but the if it's unfixable then I don't know if the contract to remove it will still stand.
    Dec 2001
    137
    23
    This is error 14 "loss of signal from CDU" ie a communications error between the indoor unit and the outdoor unit. Check the outdoor units boards and have a look for a break in the comms cable.
    Brit
    smokemare's Avatar
    smokemare Guest
    Quote Originally Posted by BritCit_Juve View Post
    Brit
    That's brilliant! Thanks, you're a SUPERSTAR!
  1. Replies: 12
    Last Post: 27-03-2011, 04:12 AM
  2. carrier fault codes
    By richelli in forum Trouble Shooting
    Last Post: 18-06-2010, 07:35 AM
  3. carrier fault code
    By emmetre in forum Air Conditioning
    Last Post: 09-09-2008, 09:31 PM
  4. mitsubishi city multi fault code
    By robin r33 gtr in forum Air Conditioning
    Last Post: 05-11-2007, 10:23 PM
  5. UA Daikin Fault Code
    By jedi in forum Air Conditioning
    Last Post: 23-07-2007, 01:44 PM
