Thread: Cold Store Panel
29-07-2008, 06:45 AM #1
Cold Store Panel
Hi All ..I am on a job where the Cold store panel has creased in numerous panels about half way up (5mts) .What are your thoughts .I tried to post photo's but the site would not allow ,If you think you can help I would email you the photo's .The store is external insulated with the steelwork on the inside of the store ,200mm panel has been used the height of the room is approx 10.5 mts
29-07-2008, 08:12 AM #2
Re: Cold Store Panel
Is the pressure relief port working and post me photos cactusstu@yahoo.com thanks
31-07-2008, 08:05 AM #3
One of the reasons could be bad foam quality. Basically the panels typically need curing time of 24 hrs after they are manufctured. If those ar shipped out before that time, this still can hapen. So also during the manufatring the Air may be entrapped. After the panel is exposd to temp variation this can happen. & ofcourse it can also be due to this Pr. relief port non working. But a Photo can help a lot. you can send that on smpsmp45@gmail.com
Construction of new Cold Store
By lalthomas in forum System OptimizationReplies: 23Last Post: 19-04-2009, 02:01 AM -
Fruit cold store design
By Josip in forum Technical SpeculationsReplies: 4Last Post: 12-09-2008, 11:29 AM -
Support for the wall panels - cold store with no locks
By smpsmp45 in forum NH3Replies: 1Last Post: 10-07-2008, 09:06 AM -
Heat load dye to Reach truck in cold store
By smpsmp45 in forum NH3Replies: 15Last Post: 17-06-2008, 11:07 PM -
Expansion Joints in the cold store floor
By smpsmp45 in forum NH3Replies: 2Last Post: 17-05-2008, 07:47 AM
