    happyjay75's Avatar
    happyjay75 Guest
    calcium Chloride with NH3 absorption
    hey guys...
    i am designing an absorption air conditioning and ice maker system... i got some questions....
    1. what's the best steel material to use as a generator?
    stainless steel? non-galvanized steel? aluminum?
    my concern in the material will be a better non-corrosive and a high thermal conductivity. im planning to used the aluminum but i dont know if it could withstand the pressure (up to 2000psi) and if it reacts with the liquid ammonia.
    2. for my evaporator:
    whats the best material for a my evaporator/ collector? ill be using brine water supplement on my NH3 collector, so it should be a high corrosive resistance.
    i am considering a stainless steel over a non-galvanized steel, it is quite expensive but do you think that it will compensate on the length of used
    thanks for the help
    Apr 2008
    South Africa
    90
    5
    Re: calcium Chloride with NH3 absorption
    What type of absorption system works on 2000 psi? The absorption systems I know work on 2000 kpa (about 300 psi). That is the ammonia, hydrogen, water systems. Here you can use any type of steel and aluminium as long as it contains no copper.
    Why use calcium chloride and not glycol?
    ddiac's Avatar
    ddiac Guest
    For sure you cannot use Stainless Steel with calcium chloride ( because of the pitch corrosion of SS due by chlor )
  1. Absorption Chiller VS Mech. Chiller
    By Intern in forum Industrial
    Last Post: 30-05-2009, 08:31 AM
  2. Absorption Refrigeration Basics
    By knudo in forum Fundamentals
    Last Post: 01-09-2008, 06:18 PM
  3. Absorption chiller in winter
    By igorb73 in forum Technical Discussions
    Last Post: 16-03-2007, 08:09 AM
  4. Can I use calcium chloride in propylene system?
    By joanna in forum Hydrocarbons
    Last Post: 23-12-2006, 10:18 PM
  5. Ammonia Absorption System
    By Samarjit Sen in forum NH3
    Last Post: 04-10-2006, 11:39 AM
