Results 1 to 20 of 20
    naveenvm's Avatar
    naveenvm Guest
    Cooling load calculation
    hi friends
    I am naveen working as a designer in middle east. i am new to this site and to this industry.
    i am working in a mep company.Here we are using software for calculating the cooling load. Can anyone send me a link for the cooling load calculation in pdf format in detail or a website address
    thanks in advance
    GXMPLX's Avatar
    GXMPLX is offline Veteran Poster I am starting to push the Mods: of RE
    May 2008
    weston
    348
    Re: Cooling load calculation
    Welcome to RE!
    You will find several if you use the search option of RE.
    Also here:
    http://www.heatcraftrpd.com/resource...H-ENGM0408.pdf
    Aug 2005
    5,302
    cooling load for refrigeration or air conditioning?
    This is why I don't like some of the software. Put numbers in and get numbers out. If you do not know what the numbers are being used for in the calculation then how do you know if the answer is correct?
    gabriel's Avatar
    gabriel Guest
    hallo,
    do enyone know how much is a training software refribase?The site is in holliday and is no way to see a price.
    Oct 2003
    5,630
    naveenvm, are you still living or will this stay a one post question?
    roland_canete's Avatar
    roland_canete Guest
    Thanks GXMPLX. this is a big help. more power.
    moideen's Avatar
    Apr 2008
    u.a.e
    48
    412
    22
    Quote Originally Posted by naveenvm View Post
    hi friends
    thanks in advance
    hi naveen,welcome to Re.in u.a.e,i think all consultants are using carrier E-cat(block load,hap) for cooling load calculation.wher are you in u.a.e.if you are in dubai,contact U.T.S. carrier at karama(contact person mr.kabeer)he will provide this software and training also)
    Moideen-dubai
    Oct 2003
    5,630
    Moideen, he was as so many a one time poster with no manners.
    He's flagged by me if he comes back.
    11,025
    Also, check the date.
    Jan 2010
    Australia
    Yes. Carrier E-cat(block load,hap) is an excellent software. It seems no other can beat it.
    Jan 2010
    Australia
    But Dubai economy seems down to the drain
    Jun 2007
    South Africa
    80
    The Heatcraft link was an excellent resource - Thanks
    Aug 2008
    Iraq
    54
    Dears,
    Many Thanks.....
    Nov 2009
    Bangladesh
    HI
    To calculate cooling load you do not need any software, it is very easy to calculate cooling load.Frist tell me is it space cooling load or refrigerant cooling load.
    U can contact me at (shameem_me04@yahoo.com) for help.
    Jul 2008
    saudi arabia
    9
    Thanks GXMPLX. expect more help
    vanste's Avatar
    vanste Guest
    see jkprosoft (I cant send url)
    bunrom's Avatar
    bunrom Guest
    Please tell me how to calculate cooling load of air con?
    Please help i'm new thanks
    mywang's Avatar
    mywang Guest
    hi all, im new here.
    i have tried "simplified cooling load" form which i get from american journal of enviromental science(yr 2005) recently from website. this form were modified from ACRI load estimation form into si unit. it stated for outside air heat load estimation; = floor area m.sq * 2.010575 + 0.708692*dt(temperature different). this formula derived from assumption of 20 frequent door usage.
    link: http://www.scipub.org/fulltext/ajes/ajes13209-212.pdf
    any comment about this formula??
    Sep 2010
    india
    i still swear by the good old excel sheets based on carrier handbook.
    can anyone suggest the % difference in heat load capacity and air flow between Softwares and manual calculations.
    May 2011
    That link was dead. I found it here:
    http://www.heatcraftrpd.com/products/PDF/Misc/CA-QC.pdf
  1. Heat transfer coefficient - Coolpack
    By Graham in forum Fundamentals
    Last Post: 28-05-2008, 01:08 AM
  2. Compressor loading, cooling, and range of operation.
  3. Cooling Load Calculation
    By jervame_sireh in forum Fundamentals
    Last Post: 21-04-2007, 11:05 PM
  4. Cooling load calculation
    By raviperumal in forum Technical Discussions
    Last Post: 02-03-2007, 04:09 AM
  5. Load Calculation / Comaprison
    By herefishy in forum Technical Speculations
    Last Post: 04-03-2002, 09:21 PM
