Results 1 to 20 of 20
Thread: Cooling load calculation
26-07-2008, 09:07 PM #1
hi friends
I am naveen working as a designer in middle east. i am new to this site and to this industry.
i am working in a mep company.Here we are using software for calculating the cooling load. Can anyone send me a link for the cooling load calculation in pdf format in detail or a website address
thanks in advance
26-07-2008, 10:07 PM #2
Re: Cooling load calculation
Welcome to RE!
You will find several if you use the search option of RE.
Also here:
http://www.heatcraftrpd.com/resource...H-ENGM0408.pdf
26-07-2008, 11:11 PM #3
cooling load for refrigeration or air conditioning?
This is why I don't like some of the software. Put numbers in and get numbers out. If you do not know what the numbers are being used for in the calculation then how do you know if the answer is correct?If all else fails, ask for help.
03-08-2008, 07:27 PM #4
hallo,
do enyone know how much is a training software refribase?The site is in holliday and is no way to see a price.
04-08-2008, 06:17 AM #5
naveenvm, are you still living or will this stay a one post question?
29-12-2009, 06:59 AM #6
Thanks GXMPLX. this is a big help. more power.
29-12-2009, 07:36 AM #7
hi naveen,welcome to Re.in u.a.e,i think all consultants are using carrier E-cat(block load,hap) for cooling load calculation.wher are you in u.a.e.if you are in dubai,contact U.T.S. carrier at karama(contact person mr.kabeer)he will provide this software and training also)
Moideen-dubai
29-12-2009, 08:30 AM #8
Moideen, he was as so many a one time poster with no manners.
He's flagged by me if he comes back.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
29-12-2009, 09:10 PM #9
Also, check the date.
08-01-2010, 06:09 AM #10
Yes. Carrier E-cat(block load,hap) is an excellent software. It seems no other can beat it.
08-01-2010, 06:11 AM #11
But Dubai economy seems down to the drain
08-01-2010, 01:50 PM #12
The Heatcraft link was an excellent resource - Thanks
15-01-2010, 09:25 AM #13
Dears,
Many Thanks.....
15-01-2010, 04:27 PM #14
HI
To calculate cooling load you do not need any software, it is very easy to calculate cooling load.Frist tell me is it space cooling load or refrigerant cooling load.
U can contact me at (shameem_me04@yahoo.com) for help.
28-07-2010, 06:03 PM #15
Thanks GXMPLX. expect more help
13-08-2010, 10:28 AM #16
see jkprosoft (I cant send url)
01-09-2010, 08:09 AM #17
Please tell me how to calculate cooling load of air con?
Please help i'm new thanks
17-05-2011, 05:05 AM #18
hi all, im new here.
i have tried "simplified cooling load" form which i get from american journal of enviromental science(yr 2005) recently from website. this form were modified from ACRI load estimation form into si unit. it stated for outside air heat load estimation; = floor area m.sq * 2.010575 + 0.708692*dt(temperature different). this formula derived from assumption of 20 frequent door usage.
link: http://www.scipub.org/fulltext/ajes/ajes13209-212.pdf
any comment about this formula??
15-06-2011, 08:51 AM #19
i still swear by the good old excel sheets based on carrier handbook.
can anyone suggest the % difference in heat load capacity and air flow between Softwares and manual calculations.
22-07-2011, 05:44 PM #20
That link was dead. I found it here:
http://www.heatcraftrpd.com/products/PDF/Misc/CA-QC.pdf
Heat transfer coefficient - Coolpack
By Graham in forum FundamentalsReplies: 10Last Post: 28-05-2008, 01:08 AM -
Cooling Load Calculation
By jervame_sireh in forum FundamentalsReplies: 0Last Post: 21-04-2007, 11:05 PM -
By raviperumal in forum Technical DiscussionsReplies: 6Last Post: 02-03-2007, 05:09 AM -
Load Calculation / Comaprison
By herefishy in forum Technical SpeculationsReplies: 11Last Post: 04-03-2002, 10:21 PM
