    Jan 2003
    East Anglia
    1,175
    Foster 1/3 Lack of airflow problem
    Evening/Morning all,
    Just thought i would share this one with you, may help out a less expreienced engineer who hasnt come across it before. I was asked by another angineer to go and have a look at a Foster 1/3 case where the opposite end to the evap, the cabinet temp was 6/7 degrees c higher than the return air at the coil.
    Turned out the centre set of drawers had the incorrect size drawer in it so was blocking the air off and short cycling inside the unit. Hopefully you can see from the picture the drawer size difference. Not one i would expect to see often, obviously someones changed the drawers at some point and only put a low sided drawer on the top on of the first set.
    Hope this makes sense.
    Fatboy
    Oct 2006
    1,848
    15
    Re: Foster 1/3 Lack of airflow problem
    Quote Originally Posted by rdocwra View Post
    Fatboy
    Good call mate.
    taz
    Apr 2006
    stafford
    36
    986
    13
    top spot,you really do have to be abit of everything for this trade,i will add detective
    Paul
    "KEEP IT COOL"
    Oct 2006
    1,848
    15
    Just thought i would share this one with you, may help out a less expreienced engineer who hasnt come across it before. Hope this makes sense.
    Fatboy
    Now stop being a cleaver sod and sort the door seals out
    Cheers taz,
    Apr 2007
    Nottingham
    26
    Hi Ray, I dont suppose this site was in Northants was it???
    Jan 2003
    East Anglia
    1,175
    Hi James,
    Afraid not, It was out Aylesbury way in the middle of nowhere. Makes a change though, i seem to be spending most of my life in the NN/MK postcode area's at the moment. OH the joys of roundabout city
    Fatboy
    Apr 2007
    Nottingham
    26
    Phew! I had replaced the drawers on the same type of unit last month at a site in Northants, for one horrible moment i thought it was my doing! If there is a next time i will look out for that one. Cheers. ;0)
  1. A strange problem
    By MuhengineeR in forum Air Conditioning
    Last Post: 27-10-2010, 05:21 PM
  2. York DXS45 capacity slide problem
    By The Screwdoctor in forum Industrial Compressors
    Last Post: 25-05-2010, 04:40 AM
  3. what's the problem
    By botrous in forum Air Conditioning
    Last Post: 22-06-2008, 02:54 AM
  4. Furance problem
    By ALONEI in forum Trouble Shooting
    Last Post: 14-05-2008, 11:32 AM
  5. York Chiller Excessive Purges Problem
    By imranmd in forum Commercial
    Last Post: 07-03-2008, 06:13 AM
