Results 1 to 2 of 2
    adrianshanov's Avatar
    adrianshanov Guest
    Question R134a System Design
    Hello everyone,
    I was asked to educated myself on R134a refrigeration system design. I know the theory behind the whole system but what I lack is how to start from a given volume of space (i.e. 25 cu.ft) and then start selecting my evaporator (coil size, width X height X depth, tube I.D. , wall thickness, Fin thickness spacing, etc.) and then condenser, and compressor and cap tube length, thickness (pressure drops?)
    I am sorry if this is a repeat thread, I had to start from somewhere.
    Thank you all, and looking forward to learning more...
    adrian
    GXMPLX's Avatar
    GXMPLX is offline Veteran Poster I am starting to push the Mods: of RE
    May 2008
    weston
    348
    Re: R134a System Design
  1. Daikin fault codes
    By Chris2005 in forum Air Conditioning
    Last Post: 21-03-2012, 10:09 PM
  2. Single stage refrigeration system optimizing diagram
    By autt in forum System Optimization
    Last Post: 03-12-2008, 03:13 PM
  3. Fan model for system optimization
    Last Post: 31-03-2007, 05:34 AM
  4. What is System balance?
    By shogun7 in forum Technical Speculations
    Last Post: 19-01-2006, 09:47 AM
