Thread: x terminal paragon clock
23-07-2008, 07:45 AM #1
If a defrost termination / fan delay switch is stuck and continuously feeds a neutral to the x terminal on a paragon clock will the system still attempt to defrost or will this stuck neutral over ride the defrost?
23-07-2008, 07:59 PM #2
23-07-2008, 08:17 PM #3
Re: x terminal paragon clock
Hello Drew. On the Paragon clocks I used to use, the x terminal was fed with a live, either switched through a stat or pressure switch. Is Paragon the P990 or was that the venner ECL? I don't know, It's been over ten years since.
23-07-2008, 11:05 PM #4
11-01-2009, 01:07 AM #5
Is the delay bad? or are you trying to determine why your defrost is terminating. The termination solenoid on the back of the 8145-20 could be swelled up (burnt) and that will terminate the defrost every time, power or no power to it. If the delay is good the warm evaporator will cause termination. Inspect the back of the timer. Unhook x and see if it will go into defrost and stay. These are the only things that will cause a termination problem
paragon defrost timer 8145-20
By kengineering in forum CommercialReplies: 4Last Post: 20-10-2009, 02:55 AM -
Hermetic compressor terminal blown off
By racknovice in forum Supermarket RefrigerationReplies: 4Last Post: 17-09-2009, 07:54 PM -
AMF/Venner Clock
By Brian Vx in forum Trouble ShootingReplies: 4Last Post: 04-03-2008, 12:23 AM -
Venner time clock
By LRAC in forum CommercialReplies: 2Last Post: 08-10-2007, 08:42 PM -
Daikin Schedule Time Clock
By breckle in forum Air ConditioningReplies: 1Last Post: 12-06-2007, 11:57 AM
