Results 1 to 2 of 2
Thread: PRV Calliberation problem
23-07-2008, 06:07 AM #1
We have YORK (model no.: YTJ3C3E25CNJ) Centrifugal chiller.
Its vanes are NOT calliberating and its NOT running beyond 65%.
We had changed vanes motor, ACC board but problem is same.
please guide to overcome this problem.
Thanks in advance.
11-08-2008, 07:50 AM #2
Re: PRV Calliberation problem
Hi Bhasadu.
I've been on J4 and J3, but honestly, i have never seen them on normal operation PRV opened more than 70%. Do you reach the set point? How are the pressures? See the liquid level. How much is HGBy-pass v/v opened.I ask because everything is complex and connected. Can you open it manualy 100%?By the way you can calibrate by means of the levers, and in fully closed position of PRV on the display you should see 5-6%. That's because vanes are never totaly closed, even in end position.
A strange problem
By MuhengineeR in forum Air ConditioningReplies: 14Last Post: 27-10-2010, 05:21 PM -
Furance problem
By ALONEI in forum Trouble ShootingReplies: 10Last Post: 14-05-2008, 11:32 AM -
York Chiller Excessive Purges Problem
By imranmd in forum CommercialReplies: 5Last Post: 07-03-2008, 05:13 AM -
Oil carry over Problem in Refrigeration Unit
By imranmd in forum IndustrialReplies: 1Last Post: 27-08-2007, 03:09 PM -
Hot start problem on VRV REYQ14M7W1B
By cool#9 in forum Air ConditioningReplies: 9Last Post: 20-04-2007, 08:09 PM
