Results 1 to 48 of 48
    Jan 2003
    East Anglia
    1,160
    Help Needed Daikin VRV
    Hello All,
    I have got to look tommorow at a Daikin VRV. I have never even seen one before let alone worked on it. I am trying to get forwarned before i get there, this is a list of all that another engineer has found and i hope someone can give me a clue what to look for.
    Fuse V1 (10amp) on top right of PCB blown
    No lights on at all on PBC
    U4 fault showing on controller.
    Apparently there is a smaller board above the main PCB with a two wire link cable going between them. This cable had been pulled off the smaller board so assume it shouldn't effect the running as i dont think the unit has been looked at previously for some time.
    Many thanks
    Raymond
    rbartlett's Avatar
    rbartlett Guest
    take space airs phone number with you
    u4 is a communication problem -usually one of the indoor units turned off
    don't expect any help off the web -daikin is the worst manufacturer for putting up service stuff
    http://www.macqueen-ac.co.uk/faqs.htm#q6
    but with fuses blown on pcb boards then expect trouble,,oh and a big phone bill and a long day
    cheers
    richard
    rbartlett's Avatar
    rbartlett Guest
    can't believe how much more sunshine you're getting in rotherwick compared to us here...
    cheers
    richard
    As a byline to this thread I hear that one of Daikins agents, Pillinger Air, is no more.
    I hope no-one got caught up in their demise.
    Oct 2003
    5,630
    The Daikin factory of VRV units is about 10 minutes drive for me. If you need some information, call me.
    Don't have mutch time now.
    Peter
    rbartlett's Avatar
    rbartlett Guest
    got any old tech manuals.? we have a 12 yr old split and daikin say they throw out after 7..
    cheers
    richard
    pillinger air is owned by daikin-as is cooling services
    Nov 2003
    NSW, Australia
    40
    242
    we get our daikins o/night to couple days...
    however i spose our importer might have done their homework on demand levels. overall found them to work quite effectively here at 40'c ambients with great faut codes even apprentices can diagnose and fix.
    "Old fridgies never die, they just run out of gas!"
    Nov 2003
    NSW, Australia
    40
    242
    cheers
    richard
    if there is any companies there that have been dealing with daikin as service agents long enough u might be lucky enough to score one, we might even have some at work no promises though... whats the model number?
    rbartlett's Avatar
    rbartlett Guest
    it's a MY90AB1
    any help mucho appreciated..
    Jul 2001
    hong kong
    65
    27
    please check the power supply for the indoor unit, one of them switch off or fuse blown will show this U4
    vB Code is ON
    Oct 2003
    5,630
    I have MY 90CJ, MY 90B, MY90CJ7.
    Can this help you and what do you need?
    If you can be more specific, i can ask it in the DAIKIN factory nearby.
    Peter
    rbartlett's Avatar
    rbartlett Guest
    yes
    i believe we need the fault codes for the outdoor pcb l.e.d's
    cheers
    richard
    Oct 2003
    5,630
    If the varistor is blown together wth the fuse, then you propably had an overvoltage. Cut the varistor in 2 pieces with a pinch and try again. Check before if voltage is within specs. Place a new varistor (we order them by Farnell in One - UK)
    Peter
    Oct 2003
    5,630
    yes
    cheers
    richard
    It took 6 scans of 1.097 kB. What do you suggest? Impossible to post
    The led functions remains almost allways the same, independent of the model.
    If anyone else need the scans, contact me.
    Peter
    Jan 2003
    East Anglia
    1,160
    Spoken to Space Air today & found them Very Helpful,
    Couldn't even get through to Daikin Themselves, didn't even answer phone.
    Anyone with daikin probs would suggest phoning Space
    Raymond
    Nov 2003
    NSW, Australia
    40
    242
    Lucky to Go's hey mark? they have many probs here, although i may be bias as we are the service agents... and it helps if the units were installed properly in the first place. but they do make up a significant number...
    PS. i will do some searching for info when i get back to work next week, a fan decided to ite me on the hand on wednesday...
    5,667
    Raymond
    Are you talking about the indoor pcb or the outdoor?
    We are daikin dealers and I'm trained on VRV
    Sorry for the late response but I've had a nice long xmas break down under and just catching up with the posts
    frank
    Sep 2003
    ISRAEL
    72
    4,248
    hi frank,
    in my country, diakin hve made thier enter just now.
    I know how it works but i am looking for literature about VRV in general and diakin in particular.
    I'm sure the stuff is some where on the web. can you give me some directions??
    thanks,
    chemi
    Oct 2003
    5,630
    We installed some VRV's. +/- 15 over the years. Daikin factory is +/- a 15 min drive for me.
    rbartlett's Avatar
    rbartlett Guest
    rbartlett's Avatar
    rbartlett Guest
    Oct 2003
    5,630
    http://www.bdt.co.nz/citymulti/how-2-pipe.asp
    http://www.bdt.co.nz/citymulti/od_super-y.asp
    good site for mitzi stuff..
    cheers
    richard
    Sorry, was to quick with my response.
    Anyhow, a VRV is the Daikin brand and Mitsubishi calls it VRF.
  23. #23
    Sep 2003
    ISRAEL
    72
    4,248
    thanks guys,
    you gave me just enough reading to do on the weekend.
    by the way, thomething you didnt know, our weekend is only saturday. on sunday we are back at work!
    chemi
  24. #24
    rbartlett's Avatar
    rbartlett Guest
    http://www.toshiba-aircon.co.uk/tech...%20Pipe%20.pdf
    handy list of all toshiba online manuals-loadsof stuff
    http://www.toshiba-aircon.co.uk/technical/manuals/
    quick before they password protect it ;-)
    cheers
    richard
  25. #25
    Oct 2003
    5,630
    Chemi,
    Have perhaps also a look at the Belgium Mitsubishi BMS system site http://www.macs-bms.com/
    System cost +/- 2500 €, included a PC.
  26. #26
    Sep 2003
    ISRAEL
    72
    4,248
    thanks peter,
    i have downloaded everything that was offerd to me and tomorow I will start the reading.
    chemi
  27. #27
    5,667
    This is the only on line manuals I could find and gives all you should need to know about designing a system or servicing one.
    http://www.cooling-services.co.uk/do...ede01-2-15.pdf
    Space Air don't post manuals on line but they do have information available in their dealer section. Not much use to anyone who doesn't have a dealer password to access it though. If you have any specific design questions or trouble shooting problems just ask.
    The MY90 is a multi split heat pump unit capable of connecting 5 indoor units. The 'A', 'C' designation after the model number denotes the series. This unit has both a 240v and 415v feed to the outdoor unit and you must energise the 250v feed before the 415v feed other wise it will fault.
    A U4 fault on the controller indicates an indoor/outdoor communication problem. If you have a dead indoor pcb then you won't get a display showing on the controller.
  28. #28
    Jan 2003
    East Anglia
    1,160
    Hello all,
    with regards to the original fault it turned out to be one of the condenser fans on the top was u/s.
    I think it had got some water into it because once it was up & running after a few blown fuses it worked ok. Obviously i have ordered a new one.
    Anyone has a problem with one of these i couldn't recomend Space more highly. They were very helpful on the phone & didn't have the attitude like some technical support offices who give the impression what are you doing working on this !.
    Raymond
  29. #29
    Jul 2001
    Fuzhou, China
    35
    Hi, everyone.
    I found a backdoor on a daikin relative site. most of literatures are password protected, but the mechanism is weak. i can't tell how to download,but i will copy them if anyone need.
    http://member.netease.com/~lincheng/...electronic.pdf
    my poor homepage,maybe a little slow, please be patient.
  30. #30
    rbartlett's Avatar
    rbartlett Guest
    lin
    that daikin pdf was pretty good..i will print it out for my guy's..any more??
    cheers
    richard
  31. #31
    Oct 2003
    5,630
    Lin,
    That link is indeed VERY good.
    I printed it out some times and gave it as Richard did to our technicians so that they can learn a little bit the electronics.
    Never saw this before in any manual of Daikin (and i have here a lot of them)
    If you can 'grab' some more of those, don't hesitate to share them. They're very usefull.
  32. #32
    Jul 2001
    Fuzhou, China
    35
    Here is 2 other:
    http://member.netease.com/~lincheng/...checkpoint.pdf
    http://member.netease.com/~lincheng/...isetrouble.pdf
    I'm still on the way of "grab" more, i will post them here one by one.
    Please enjoy silently, then we will keep up with their any new update.
  33. #33
    Oct 2003
    5,630
    Strange, the 1st manual came from Ostend (the European factory here nearby, +/- 15 miles) and never saw such a manual before.
    I think they will be very usefull also.
    I said this to MarcFiddi, I also have (printed versions) of Smeva counters Showmaster. If anyone needs sometimes some information, call me.
    Peter.
  34. #34
    rbartlett's Avatar
    rbartlett Guest
    yes many thanks lin ..;-)
    i have saved them to my p.c so if the link disappears i can always get it...
    cheers
    richard
  35. #35
    Sep 2003
    ISRAEL
    72
    4,248
    thanks lin ,
    I've read the whole thing. very interseting .
    this year is the first year that daikin is entering our market.
    it will be dificult for them as its hard to find a house without air-conditioner in it.
    by the way, most of the stuff being sold here, comes from your counry. but the best and more expensive is local made.
    chemi
  36. #36
    rbartlett's Avatar
    rbartlett Guest
    the best ? please let me know which manufacturer you are thinking of -not amcor surely??
    cheers
    richard
  37. #37
    Sep 2003
    ISRAEL
    72
    4,248
    hi richard,
    defenatly not amcor, they are no longer on the map!! piece of sh..t.
    tadiran, elco and electra. three very good companies.
    elco is one the biggest companies in the world, manufactur in israel, china, europe, australia, electronic - boards factory in hong-kong and many marketing companies all over the world.
    we sell over here over 100000 units per year.
    just yesterday I got a lorry full, thats 35 units and they already sold!!
    I personaly work with tadiran, carrier is holding 30% of them so big brother is watching of the quality, and they are good.
    chemi
  38. #38
    Sep 2003
    ISRAEL
    72
    4,248
    hi richard,
    many small importers bring cheap units from china but they are improving rapidly. so far they are not too reliable.
    at home I have three elco and one sanyo from thier factory in italy.
    chemi
  39. #39
    rbartlett's Avatar
    rbartlett Guest
    i saw my first elco on a job for marc..
    these were a few yrs old but based on those-'okay' is about as far as i'd go...
    cassette quality -upper 'budget' condensers big heavy
    no diagnostics etc..
    daikin are very good quaility wise -ask peter1 for a trip to the factory- a really excellent facility
    carrier splits are only okay if toshiba are involved ( carrier have been re-badging tosh for 20yrs or so)
    cheers
    richard
  40. #40
    Sep 2003
    ISRAEL
    72
    4,248
    well richard,
    I can not argue with that. I agree that world wide best split air conditioners are the japanees. but they are not available everywhere.
    childish political reasons avoided the japanees companies from selling over here.
    within the local market, the companies I have mentioned, are the best.
    in my living room there is an elco split for 11 years. nver touched it exept for cleaning filters or washing condenser after a sand storm. I call that exelance. controls by motorola.
    if all air coditioners would have been so reliable, most of us would have been plumbers or electricians or god knows what.
    the expected "life" should be about 5-6 years.
    I defenatly take your invitation to visit daikin with peter in belgium and finish the tour at his wife's tea - room for a pint of good ale.
    will you come too?
    chemi
  41. #41
    rbartlett's Avatar
    rbartlett Guest
    yes -lets all invite ourselves to peters' house !! ;-)
    cheers
    richard
  42. #42
    Jul 2001
    Fuzhou, China
    35
  43. #43
    Oct 2003
    5,630
    Hi all,
    Read all the post the last days but I was too busy preparing my theoretical flying lessons (descending, turning and banking and stall) which I had to give last Saturday.
    Sure, I can arrange a visit in Ostend but frankly, this is not so nearby for most of you all.
    Even for us, when we have to order something, we must go via the Belgium Daikin sales office in Brussels.
    We had once a broken Daikin compressor in a factory (KODAK) in the same street as the Daikin factory. It took 3 days before it was delivered. They then decided to never install Daikin anymore.
    It became Carrier (it can now last 3 weeks before we have one )
    Sure, Chemi can then afterward drink her Abbye Beer (9,5%) and her famous Poffertjes or taste one of the 25 different variations of coffee.
    On her website, I have translated (from the English) the strange story of the most expensive coffee in the world (only 500 lbs or 250 kg production in a year) Kopi Luwak.
    She don't sell it !!
    http://dreamship.com/kopi_luwak.htm
    Lin and the others, If you need something from Mitsubishi, I have a CD with all the service manuals
  44. #44
    rbartlett's Avatar
    rbartlett Guest
    lin
    is it http://www.cooling-services.co.uk??
    cheers
    richard
  45. #45
    Jul 2001
    Fuzhou, China
    35
    sh
    let them sleep. i still wait for their vrv2-plus manuals(still havn't gone to europe?)
  46. #46
    rbartlett's Avatar
    rbartlett Guest
    cool
    but i have password too :-))
  47. #47
    OK, Richard.....give
  48. #48
    5,667
    We've just got our hands on the VRV II tech manuals on CD
  1. Daikin Analyzer
    By marc5180 in forum Fundamentals
    Last Post: 02-08-2008, 07:15 PM
  2. Daikin Controllers
    By airefresco in forum Air Conditioning
    Last Post: 15-05-2008, 08:08 AM
  3. !!big Daikin Problem!! Codes,u4,pj, And E0
    By airconengineer in forum Air Conditioning
    Last Post: 31-05-2007, 09:04 PM
  4. Daikin problem
    By Jambo in forum Trouble Shooting
    Last Post: 28-07-2006, 07:42 PM
