Results 1 to 1 of 1
22-07-2008, 06:43 PM #1
Manitowoc remote condenser install
I've got a new Manitowoc S-500 with a JC-0495 remote condenser I need to install. Am I correct in assuming that I can just connect the pre-charged line set, run the power between the ice machine and condenser, open the valves and it's ready to go? The condensing unit is also pre-charged. Are there any other items that need to be checked? Anything in particular to look out for? I haven't worked with a remote condenser machine with everything pre-charged with refrigerant.
Thanks, Steve
Manitowoc Ice machine taking too long to harvest..
By nyTroX in forum Trouble ShootingReplies: 26Last Post: 08-05-2011, 09:39 PM -
Air Cooled Condenser Leakage Problem with R-404A
By RADHAKRISHNARAO in forum Technical DiscussionsReplies: 19Last Post: 30-07-2008, 12:21 PM -
Remote condenser + heat recovery
By Renato RR in forum Technical SpeculationsReplies: 9Last Post: 30-03-2006, 07:26 AM -
Remote condenser
By Rfcont in forum Technical DiscussionsReplies: 7Last Post: 06-12-2005, 12:44 PM -
Remote Control problem
By botrous in forum Air ConditioningReplies: 2Last Post: 12-10-2005, 05:36 PM
