    May 2008
    Australia
    64
    Heating not working on split system what is the problem?
    Hello,
    I'm a fridgy and i've only done install my whole career im now moving out and doing a bit of service work as well, i had a customer call me and ask me to have a look at their split system that is not working in heating mode. I was just wondering what you guys would think the problem is give the details i was given?
    I have a fair idea of the problem but i just want to what you guys make of it and what you would first look for once arriving at the job.
    It's a reverse cycle split system and it works fine on cooling but once it is switched over to heating the compressor kicks in and runs but the indoor unit only blows ambient air................that's all the details i was given.
    Any help would be great
    Aug 2004
    744
    Re: Heating not working on split system what is the problem?
    First and most important, is the controller set to heat and to a temp above room ambient? You know what customers are like.
    Second, is it above 10degC outside? Some splits wont work below this.
    Third, is the reversing valve working?
    Fourth, discharge temp, hows the gas charge?
    This should get you on your way
    Eggs
    London
    82
    Quote Originally Posted by eggs View Post
    Eggs
    Spot on Eggs,all he has to do next is to follow your advise and i am absolutely sure it is one of the mentioned.
    May 2008
    Australia
    64
    Hello,
    Thanks for the replies sorry i forgot some of those details..........yes it is set on heating and it is above 10deg outside.
    My guess without going to the job and given the information above was reversing valve.
    What is the best way to know if the reversing valve is stuffed? just listen to see if its working and feel the pipes? is there any special requirements in changing the R/V?
    Also will my local heatcreaft carry a replacement or will i need to contact the units manufacturer?
    May 2008
    Australia
    64
    Ok just got some more info..........
    It is a carrier unit when on heating the compressor runs and the outdoor units fan blows cold air (so the reversing valve is working true?)
    They have told me that the indoor unit only blows air really softly if any and is at a ambient temperature.
    I was also told that they actually haven't tried it on cooling as of yet.
    The unit is 5 years old.
    Any Ideas?
    May 2008
    Australia
    64
    any ides guys?
    Dec 2006
    Mansfield
    231
    Get yourself to site never try and fix a problem before you have seen the job, could be something really simple like a blocked filter.
    Keep us up to date on how you get on.
    PP
    Sep 2003
    ISRAEL
    72
    4,248
    Not much to add after all the ideas but a few things.
    Check pressures, discharge and suction, unit might have lost some charge.
    feel by hand the pipes going out of the 4 way valve, you want to feel cold and sweaty suction and real hot discharge.
    Look for frost signs on the bottom out side coil.
    Nov 2006
    Cheshire, UK
    56
    360
    I've had a couple of heat pumps over the last year or so that have had stuck reversing valves due to being used solely on one setting.
    Switch off power completley and give the valve a 'measured' smack with the handle of a screwdriver etc.
    Switch back on and all may be well!
    If not, hit it harder!
    He who dies with the most Toys, WINS!
    Jan 2003
    Crewe, United Kingdom
    58
    723
    22
    Quote Originally Posted by sinewave View Post
    Do make sure that the screwdriver has been calibrated though
    Karl
    Nov 2006
    Cheshire, UK
    56
    360
    Oh aye, forgot that bit!
  1. Problem with an inverter compressor in V.R.V system DAIKIN R 407
    By Harris Greece in forum Air Conditioning
    Last Post: 24-11-2007, 12:53 AM
  2. Multi Split and VRV
    By Abe in forum Air Conditioning
    Last Post: 20-08-2007, 01:12 PM
  3. coil temp for r22 split system
    By ctct in forum Air Conditioning
    Last Post: 28-07-2007, 09:36 PM
  4. Migrate Oil problem - Medium Refrigeration System
    By lurioda in forum Fundamentals
    Last Post: 24-02-2004, 06:20 AM
  5. Refrigeration system proposal; comments please.
    Last Post: 01-01-2003, 03:42 PM
