Results 1 to 9 of 9
    Dec 2004
    Weihai,China
    800
    heat pipe recovery issue
    Hi sirs
    I want to apply heat pipe recovery in our dehumidifier. See attached picture.
    Anybody know how to manuacture heat pipe? is it cost effective in this field?
    thanks and regards
    LC
    Jul 2007
    Qatar
    54
    8
    Re: heat pipe recovery issue
    Quote Originally Posted by Lc_shi View Post
    Hi sirs
    thanks and regards
    LC
    check this web site for ur heat pipe requirements.
    spcoils.com
    Jul 2007
    Qatar
    54
    8
    Quote Originally Posted by Bullet View Post
    spcoils.com
    sorry
    spcoils.co.uk
    Sep 2003
    ISRAEL
    72
    4,248
    Hi Bullet,
    Maybe you will bring here some more info about heat pipes for the befit of all the readers?
    May 2006
    aberdeen
    124
    Sorry but i do not understand your attached diagram.
    is the air moving from, left to right, passing over a hot pipe then a cold pipe then a hot pipe again?
    Please could you give a little more info.
    Dec 2004
    Weihai,China
    800
    It's a U-shape heatpipe which put in the inlet and outlet of cooling coil which perform precool and reheat and need no energy input.
    Jan 2006
    Croatia
    68
    2,261
    31
    Feb 2006
    Mumbai
    49
    Hi Li,
    Wanted to use Heat pipes for reheat in one of our projects. Was working with Heatpipes Inc. India subsidiary....however answer to fluid being used in "Its proprietary".
    We had reviewed U type heat pipes, which takes heat from inlet air to cooling coil and provides it at outlet of cooling coil for reheat thus reducing cooling as well as heating capacity.
    However, cost of the equipment did not turn out to be viable in our case.
    Vijay Kumar
    Vijay Kumar
    HVAC Design Engineer
    BMCPL
    "The more you sweat in peace less you bleed in war"
    nambkdn's Avatar
    nambkdn Guest
    Very good!Thanks
  1. Capacity control
    By sparrow in forum Training
    Last Post: 18-01-2010, 07:49 PM
  2. Replies: 5
    Last Post: 14-09-2009, 07:33 AM
  3. frostles heat pump
  4. Heat recovery and aquifer heat/cold storage
    By RicHoe in forum Supermarket Refrigeration
    Last Post: 23-06-2006, 01:24 AM
  5. Remote condenser + heat recovery
    By Renato RR in forum Technical Speculations
    Last Post: 30-03-2006, 07:26 AM
