Results 1 to 29 of 29
Thread: Deep vacum problems
Threaded View
02-08-2008, 04:55 PM #6
Re: Deep vacum problems
Well guys still having all the same problems as before, I have removed the filter drier as well now but this R14 refrigerant seems to be blocking the cap tube, the temperature starts to come down to around -130c then it slowly starts to rise again back up into the + fingers, there is very little cooling on the suction line and is ain a deep vacuum all the time with high pressures from the liquid line.
I have tried all that has been stated but still am having these problems, is there any way I can get over this problem or is this typical of the R14 refrigerant, would changing the cap tube I have from .036 to .042 help at all as the cap tube I have and the refrigerant used seems to just be blocking in the cap tube.
Any help would be gratefully welcomed.
Carrier 30XA Liquid chiller Problems
By Ed Burris in forum CommercialReplies: 7Last Post: 13-08-2010, 08:12 PM -
samsung rs21dcns problems
By slovenian ian in forum Trouble ShootingReplies: 2Last Post: 03-11-2007, 03:19 AM -
Oversized Liquid Recievers?? Problems??
By nickjh in forum FundamentalsReplies: 12Last Post: 12-06-2007, 07:54 AM -
Oil return problems
By Peter_1 in forum IndustrialReplies: 37Last Post: 23-08-2004, 11:30 PM
