Results 1 to 10 of 10
Thread: Co2 systems
    Aug 2002
    Bristol
    71
    5
    Cool Co2 systems
    Hi has any one come across transcritical systems working on Co2, I know that Linde have a number of systems installed ove europe?
    Oct 2007
    52
    7
    Re: Co2 systems
    Star Refrigeration are punting a small one, athough I believe they dont have any tried and tested in the field
    Mar 2006
    Merate (LC) - Italy
    2,549
    Re: Co2 systems
    Yes, I have. Linde, Knudsen Koling, Ahlsell.... questions?
    Jul 2001
    Sydney, Australia
    753
    Re: Co2 systems
    There is one installed in a supermarket in Adelaide Australia
    ...and she said "give it to me you big fridgie"
    Aug 2002
    Bristol
    71
    5
    Re: Co2 systems
    Hi all thanks for replys, I was after some information with regards the Transcritical side of things, i believe there are no condensers on this type of system?
    Mar 2006
    Merate (LC) - Italy
    2,549
    Re: Co2 systems
    What was called condenser in a subcritical or normal cycle, here is called "gas cooler".
    GXMPLX's Avatar
    GXMPLX is offline Veteran Poster I am starting to push the Mods: of RE
    May 2008
    weston
    348
    Re: Co2 systems
    You donīt condense in a transcritical system so you donīt have a "condenser" but you do have a heat exchanger that does the same function: reject heat of compression+heat absorbed.
    Aug 2002
    Bristol
    71
    5
    Re: Co2 systems
    How does the gas cooler work? how do you get liquid?how do you maintian liquid pressure?
    Mar 2006
    Merate (LC) - Italy
    2,549
    Re: Co2 systems
    the gas cooler does what it says: it cools the gas, but being supercritical, it doesn't condense, so you don't get liquid.
    After the gas cooler, a special regulation valve is installed, which lowers the pressure (it's a throttling device, like a TXV, but unlike a TXV it doesn't throttle liquid). As the pressure lowers, the gas approaches the critical pressure and transforms into liquid.
    The difference between a normal cycle and a transcritical one, is that in the latter liquid forms after the throttling device, while in the former cycle liquid is present already before of it.
    Aug 2002
    Bristol
    71
    5
    Re: Co2 systems
    Thanks all is becoming clear.
  1. contaminants in ammonia systems
    By Johnny Rod in forum Refrigerants
    Last Post: 17-10-2011, 05:26 PM
  2. Co2 Systems in Supermarkets
    By 750 Valve in forum Supermarket Refrigeration
    Last Post: 19-10-2007, 08:51 AM
  3. My local Apprentice Training Classes
    By shogun7 in forum Training
    Last Post: 17-03-2007, 03:10 PM
  4. HFCs for flooded systems?
    By garyb in forum Refrigerants
    Last Post: 21-04-2006, 10:02 PM
