    netingit's Avatar
    netingit Guest
    Question John Lewis, fridge warm but freeze ok
    Hi guy,
    Just came across this superb webstie and wondered if you could give me any advice on this one.
    I've had the John lewis fridge model jffs2002 for about three years now, about a few weeks back i started noticing that the fridge part was quite warm with a warning light flashing showing temp error.
    I've had a engineer take a look at it, who has told me that it was a common problem with frost free fridge/freezer. He advised to turn it off for 24h so the fridge could defrost due to ice blocking the pipe's that the cool air flows through. Followed his advice, the Fridge worked prefect for 1 day then reverted back to the same problem. Got him to take a look at it once again, he advised me once again to leave it off for a few days. He did say that he could speed up process of the defrost if only he could gain access to the internal parts of the fridge (will get back to that in a sec).
    once again followed his advice, but left the fridge off for 1 whole week! turned it back on, it worked prefectly for 3 days, but now has gone back to it old ways (fridge warm with warning light on).
    Not sure what to do should i call the engineer back to take a look once again?
    Also this is the first fridge which i've come across to have a back which is completely sealed, in the manual it shows how to clean the condenser on the back, but there's no condenser to be seen, the back of the fridge is completely sealed by a white piece of cardboard. is this normal?
    Any help will be very appreciated
    Oct 2006
    1,843
    Re: John Lewis, fridge warm but freeze ok
    Quote Originally Posted by netingit View Post
    Hi guy,
    Hello.
    A few things to remember with auto defrost freezers is they do ice up occaisionaly.
    But if after defrosting it ices up again then there seems to be a problem with it.
    This type of fridge has a timer in it (mechanical or electronic) that puts it on defrost.
    When on defrost the compressor stops running which alows it to warm up.
    To speed the process up a heater comes on inside the freezer to melt any ice.
    After a set time or a set temp the thing changes back to refrigeration mode and
    the thing works as a freezer again.
    Somthing in that cycle could be faulty and it could be one of ten things so to be
    done properly it does need looking at.
    I do not want to say anything about the engineer who looked at it before.
    You need somone who is familier with domestic fridges. There are people on this
    site who can tell you better but there is another site.
    Pssst Psst (taz whispering try) http://www.ukwhitegoods.co.uk/
    They might be able to help you
    taz looks over his shoulder to see if the coast is clear
    Don't tell anyone I told you.
    taz
    netingit's Avatar
    netingit Guest
    Hi Taz,
    Thanks for your reply, will give the site ago
    Thanks again
    11,025
    Nohing wrong with WhiteGoods Taz, I specify them myself sometimes.
    It's safe to come out from behind the pub now...
    Oct 2006
    1,843
    And heres me thinking I'd got away with it .
    Cheers taz
  1. fridge warm freezer cold?
    By babsnsarah in forum Domestic
    Last Post: 30-04-2011, 04:24 PM
  2. crazy 3rd-world idea: aircon from small fridge
    By lsemprini in forum Fundamentals
    Last Post: 29-05-2008, 01:10 AM
  3. Hoover Optima - Freezer warm, fridge cold
    By aberchick in forum Domestic
    Last Post: 08-05-2008, 09:45 PM
  4. Samsung RS21 DCNS Fridge too warm
    By Divekate in forum Trouble Shooting
    Last Post: 26-02-2007, 05:12 PM
  5. Zanussi - fridge is warm but freezer is cold.
    By Bob Ball in forum Trouble Shooting
    Last Post: 11-02-2007, 04:59 PM
