Results 1 to 16 of 16
    luke.180's Avatar
    luke.180 Guest
    What gauges can i use for R407c????
    I just baught a air con for my appartment and its got R407c gas and ive never delt with it before. Can i use my R22 gauges or my R410a gauges??
    Or do i have to go and buy gauges that are for R407c?
    Thanx
    GXMPLX's Avatar
    GXMPLX is offline Veteran Poster I am starting to push the Mods: of RE
    May 2008
    weston
    348
    Re: What gauges can i use for R407c????
    Yes, gauges measure pressure and R22/R407c can be measured by the same instrument unlike R410a (with higher pressures probably needs a wider range gauge).
    What you should not use is the temperature scale. I'm not saying you can't because temperatures are close enough but you introduce an error.
    It's better to use the same gauge but if you want the saturation temperature, look in a chart for R407c.
    Sep 2005
    spain
    54
    I can not belive the mods have not picked up on this!!!!!as i know all gauges that compare 22 will have 407 and 134 and pos 404. YOU will have come across this if you know what you are doing??
    Sep 2005
    spain
    54
    And if you have just bourght it and i presume are fitting it your self what do you need the gauges for unless there is a problem with the install.Gauges are ONLY used for diagnostics and poss inital vac If you do that??
    GXMPLX's Avatar
    May 2008
    weston
    348
    Quote Originally Posted by coolflow View Post
    I can not belive the mods have not picked up on this!!!!!...??
    You mean your avatar???
    I can not believe the mods have not picked up on this!!!!!
    as i know all gauges that compare 22 will have 407 and 134 and possibly 404.
    Please explain in unexcited text why you think that a Moderator should have responded instantly to this thread.
    Also, your assumption that all R22 gauges have the other refrigerants on the dial is incorrect. There are many on the market that have a single refrigerant scale.
    Your final sentence assumes that all technicians are at the same level of competence as yourself and we take it on trust that you know what you are doing
    Sep 2005
    spain
    54
    NO !!407 has been around for years and this chap would have been better asking his work coliges or his collage tutor. and when was the last time any one bought single referance gauges (it is possible but unlikly).and Brian you have helped me in the past( thanks a grate deal),i did not mean instantly but you change like the wind.One thred i reed no probs hears the help...... then the other is as if you dont know dont touch it! Explain.And i am not having a go at the mods!
    May 2006
    Porto - Gaia
    48
    10
    R407c pressures are very close to r22 pressures
    Feb 2006
    derbyshire
    610
    maybe he,s just a tad busy like all of us at present
    Jan 2008
    Norfolk - England
    95
    sounds about right old gas bottle,
    i'm choked at the moment, might have a beer or take it out on the cat (poor tiddles)
    Oct 2003
    5,630
    If we should respond to all the questions, why we then nee you members any longer?
    Our main purpose is to moderate this forum, not to answer questions.
    Making that this forum stays like it is now.
    And we don't sit every second before our computer, we have also an normal life.
    luke.180's Avatar
    luke.180 Guest
    Thanx for your help guys, It was a simple question that i wasnt shore about,and for the record my gauge has othe gases on it but not r407c. Its a shame that there is smart asses like you everywere,I bet you wouldnt be a smart ass if it wasnt over the net
    Sep 2005
    spain
    54
    Its called ying-yang...while there will be smart asses there will also be dumb asses as well!!
    Dec 2008
    42
    My gauges do not show R407 on it either I just use r410A gauges...
    Jan 2010
    wales
    56
    55
    close enough figures aren t good enough you got readings for r407c and r22 for these systems to run with most efficiency thy ve got to right i m glad some of you don t work for me i would have more callbacks for systems not working correctly than i could deal with . people come to this forom for profesional advice not guess work
    Dec 2008
    42
    Quote Originally Posted by freezetech View Post
    Yes this is true. If I needed temps i would definitely acquire the appropriate gauges. I currently work on ULT Freezers and only need to worry about pressures. The temperatures I need and use are inside the Heat Exchanger Condenser. Plus in our system we use R407D. Happy Trails....
  1. Digital Refrigeration Gauges
    By o5g in forum Tools and Calculators
    Last Post: 02-09-2008, 09:14 PM
  2. Electronic vacuum gauges
    By smpsmp45 in forum Trouble Shooting
    Last Post: 23-06-2007, 04:37 AM
  3. A/C not putting out enough cooling, gauges not happy
    By Larry2 in forum Air Conditioning
    Last Post: 13-11-2006, 08:32 PM
  4. Ammonia Gauges?
    By nomiracle in forum Fundamentals
    Last Post: 26-07-2005, 02:19 AM
  5. Reading compound gauges
    By kitt3n in forum Refrigeration Books
    Last Post: 27-04-2004, 11:14 AM
