Results 1 to 18 of 18
    WarwickH's Avatar
    WarwickH Guest
    Bitzer BSE170 ester oil
    Hello all
    I am a new member and I am hoping that someone out there can help me with information. Does anyone know the pour point of Bitzer BSE170 ester oil? If you do know what the pour point is, do you have any documentation or know a link to something official.
    Thank you in advance for any help that is offered.
    GXMPLX's Avatar
    GXMPLX is offline Veteran Poster I am starting to push the Mods: of RE
    May 2008
    weston
    348
    Re: Bitzer BSE170 ester oil
    It doesn't have one, it simply freezes.
    Also doesn't have properties like aniline point, used in complex mixtures like mineral oils wich are petroleum destilates.
    POE is a pure substance it doesn't separate wax nor other "stuff".
    Don't have much info but you can ask the experts here:
    http://63.111.59.207/Uniqema_Compres...ion=Compressor
    GXMPLX's Avatar
    May 2008
    weston
    348
    Interesting, this leaflet does indicate pour point for POE:
    http://www.uniqema.com/irj/servlet/p...-27-25-252-123
    ... never too late to learn something!
    WarwickH's Avatar
    WarwickH Guest
    Very true GXMPLX
    Yeah, most POE manufacturers publish a pour point for their oils - general rule of thumb has always been that as viscosity increases, so does the pour point. Don't seem to be able to find any Bitzer material though that shows the pour point for any of their oils.
    Jul 2008
    Singapore
    11
    Hi!
    Pour pt should be -24 deg C. Test method DIN ISO 306. This are specification from FUCHS triton SE-170 similar to BSE-170. In most cases, application for for screw compressor.
    Hope it helps
    WarwickH's Avatar
    WarwickH Guest
    Thanks KOH
    I also have a figure of -25 deg C for Emkarate RL170H - same viscosity so expecting similar figure for BSE170. Would like to have something official from Bitzer though, I've seen cases before where there is a large difference between different brands of same viscosity oil.
    Mar 2006
    Merate (LC) - Italy
    2,549
    Of course there is a pour point. Infact it doesn't freeze. It just becomes so thick, that it doesnt flow.
    There's nothing like a frozen oil.
    florin0312's Avatar
    florin0312 Guest
    Where can i found specification about BSE 170?
    florin0312's Avatar
    florin0312 Guest
    Where can i found a softwere for oil/air cooler for refrigeration system?
    Farid Zeynalov's Avatar
    Farid Zeynalov Guest
    Hi.
    I need an advise.
    I have 2 BITZER screw compressors.
    The oil is Bitzer BSE 170.
    i cannot find this oil in Azerbaijan, i found only BP ENERSYN MPS170. Can I use this oil?
    Mar 2006
    Merate (LC) - Italy
    2,549
    No, unless it's a R22 system. In fact the catalogue says: "suitable for use with R 22 and R 502 refrigerants but not HFC's"
    nazrul islam's Avatar
    nazrul islam Guest
    hi friends ,
    i m from BANGLADESH .
    plz ny one can help me ?
    i have 2 bitzer screw compressor .
    i cant find bse 170 oil in bangladesh .can u advice me ny oil which oil i can use ?ny one know bp ,mobil ,castrol have bse 170 alternative oil ?
    thanks
    Mar 2006
    Merate (LC) - Italy
    2,549
    Castrol Icematic or Mobil Arctic with same viscosity would do the job.
    Auckland
    74
    3,357
    38
    Hi No Name nick
    I have several Bitzer screws on 22, and have been using there gluey what ever oils at horrendous pricing, is there an alternative regular type oil that is complient to specification. Like here 18 litre can is 1000.00 plus dollars
    Mar 2006
    Merate (LC) - Italy
    2,549
    What is the spec for that bitzer oil?
    morteza110213's Avatar
    morteza110213 Guest
    Hello.
    I need an advise.
    what is diffrence between these oils:
    BSE 170 & POE 170?
    morteza110213 Guest
    Hello.
    I need an advise.
    BSE 170 & POE 170?[/quote]
    Mar 2006
    Merate (LC) - Italy
    2,549
    Quote Originally Posted by morteza110213 View Post
    Hello.
    I need an advise.
    BSE 170 & POE 170?
    No difference what so ever.
  1. Bitzer gasket
    By Renato RR in forum Fundamentals
    Last Post: 04-11-2010, 10:08 AM
  2. Bitzer s6f30 2-stage compressors
    By JONAH in forum Technical Discussions
    Last Post: 27-10-2010, 07:27 AM
  3. 410-A Polyol Ester
    By paradiseair in forum Refrigerants
    Last Post: 31-03-2007, 04:18 PM
  4. Ether or Ester?
    By Daddy Cool in forum Air Conditioning
    Last Post: 29-04-2006, 03:08 PM
  5. R-22 with ester oils
    By Friobernal in forum Technical Discussions
    Last Post: 24-05-2002, 05:11 PM
