Results 1 to 14 of 14
    Jun 2005
    California
    394
    Replace condenser fan motor
    I am curious as to how you would replace a defective fan motor on a 2 ton 8 year old straight air conditioner when there is no information avialible on the motor. Replaceing the unit is not an option and mfg out of business.
    GXMPLX's Avatar
    GXMPLX is offline Veteran Poster I am starting to push the Mods: of RE
    May 2008
    weston
    348
    Re: Replace condenser fan motor
    Trial and error!
    Ancient technique.
    3,853
    You could take the old motor to your wholesalers and see if they have a similar one, or fit one that is the same size, possibly with a new blade from another manufactures range of units of a similar size, or take the old motor to a motor rewind shop and get it fixed.
    Jon
    Jun 2005
    California
    394
    If you can determine the CFM of the condenser then can you figure out how to get a replacement motor.
    Aug 2005
    5,302
    Quote Originally Posted by wambat
    Now where is the fun it that?
    Another way is to measure the blade pitch and diameter and look at some fan curves for various RPM's as a reality check for your method also.
    Two guesses that get the same approximate answer are pretty good at eliminating doubt.
    Jun 2005
    California
    394
    The fun is in the "how do I find the cfm" so your the technition on a hot roof and the customer is in desperate need of cool air. What's your stragity?
    Of course you can always punt
    Jan 2007
    scotland
    159
    why not get the motor rewinded sometimes can be a bit pricey but can get you out of a tight spot also these guys a quite good at finding out the make/model of the motor just by looking at it
    Jun 2005
    California
    394
    Quote Originally Posted by fowlie View Post
    That's an option but I was just curious if others had a solution like what i was thinking of. US Iceman has one possible solution.
    Jun 2006
    63
    10
    Typicly, a 2 ton unit will have 1/4 hp 1075 rpm motor. Some mfgs use a 1/4 hp 850 rpm like York. On rare occasion they will go either way by putting in a 1/3 or 1/5 hp motor, so check the capacitor, typicly you would see a 5 mfd cap on a 1/3 and a lower mfd like a 3 on a 1/5. But a 5 would be on a 1/4 as wel. What I did in the field was just put in a 1/3, 1075, and new cap, verified the amp draw that it wasn't over amping and called it quits. The customer gets their air conditioning back, you get to the next job and everybody is happy. No time wasted. Hope this helps.
    Jul 2008
    Southeastern US
    11
    Is there no dataplate anywhere on the unit? Not even a model & serial number sticker? (Have you checked the compressor and the bottom perimeter of the housing for an oem sticker?) What is the make?
    McGuiver's recommendation makes the most sense to me, especially since it's an orphaned eight-year-old condenser. I mean... just how critical is this system?
    by
    Aug 2005
    5,302
    I think the purpose of this exercise is to show you you some different ways to determine information, when you lack the labels and tags which we assume are required to find the correct parts.
    wambat... please feel free to jump in here if I misspoke.
    Auckland
    74
    3,357
    38
    Check out the overload / current protection device, that will target the max amps before destruction, check blade diameter, work backwards so to speak. If blade looks like meaty bites of air then is slow speed, fine angle and lotz of flat blades, then high speed.
    magoo
    Jun 2005
    California
    394
    That's correct
    13
    It's no big deal -- I do it all the time, and I'm a PE.
    You can get generic fractional HP motors that will fit any application.
    The main thing to remember is to disconnect the lead on the dual capacitor and wire in a 5 mfd cap on the new motor.
    So easy a caveman can do it (or a PE engineeer like me )
  1. Superheat and Subcooling
    By Chunk in forum Fundamentals
    Last Post: 15-01-2011, 01:24 AM
  2. Compressor loading, cooling, and range of operation.
  3. help with testing 3 phase comp
    By mat in forum Fundamentals
    Last Post: 19-01-2007, 09:03 AM
  4. locked rotor amps (LRA)
    By vinod in forum Technical Discussions
    Last Post: 09-09-2006, 12:50 AM
  5. current draw on condenser fan motor
    By dan wong in forum Trouble Shooting
    Last Post: 25-05-2001, 06:12 AM
