    RCL's Avatar
    RCL Guest
    How best to measure compressor run time?
    This may well have been covered before, especially with me being a new user, so feel free to point the direction of an old thread.
    What I'd like to know is your product recommendation for the best/simplest way to measure compressor run time hours for a commercial walk-in freezer over 2 weeks?
    At this stage I'm considering a HOBO state logger connected to a clamp-on current switch or maybe one of those small magnetic field motor on/off recorders.
    Any advice from those that have been there before?
    Feb 2007
    58
    158
    Re: How best to measure compressor run time?
    Am I missing something here?
    Surely the easiest/cheapest way is just to fit a simple hours run meter to the contactor.
    Oct 2006
    Bucks, U.K.
    71
    604
    As Plank says use a hours run meter.
    A long time ago I made up a box with x2 hour run meters in. One records the 'Total time' the other records 'running time'.
    You record the dials at the beginning, and at the end....you do not have to worry about an exact number of hours, days, weeks etc as you have the 'total' hour meter to give you that.
    Simple maths then gives you % figure or run time / 24hrs.
    Keep it Simple!
    GXMPLX's Avatar
    GXMPLX is offline Veteran Poster I am starting to push the Mods: of RE
    May 2008
    weston
    348
    Do as they say but if the compressor has internal overload add a current relay so that if the overload trips you cut the supply to the meter.
    Nov 2005
    211
    Just get an analog clock, set it to 12:00, and connect it in parallel with the compressor (using a voltage converter if needed).
    "If Hannah was an air handler, I would be a condensing unit so I could open her TXV and pump my refrigerant through her coils." - a HVAC friend of mine
    Mar 2007
    INDIA
    42
    31
    If you use the data logger which measures all parameters then it will be simple as well as fruitfull also.......
  1. Replies: 12
    Last Post: 27-03-2011, 04:12 AM
  2. Leak Testing?
    By Thana in forum Trouble Shooting
    Last Post: 31-08-2010, 02:57 PM
  3. TK basic micro-p features and functions
    By REEFER-TEK in forum Transport
    Last Post: 05-12-2007, 06:25 PM
  4. what do you do on your off time?
    By Tycho in forum Chit Chat & Service Stories
    Last Post: 09-10-2006, 12:03 AM
  5. Time delay for multi compressors
    By iceman007 in forum Air Conditioning
    Last Post: 06-11-2004, 08:05 AM
