Results 1 to 13 of 13
    Jan 2006
    Norway
    1,036
    4
    31
    wireless temperature sensors
    I've just gotten my hands on some wireless temperature sensors.
    I don't know if this is new in the trade, but it's new to me. I have just started playing with it here in norway
    and the basic application seems ok, it gives a temperature reading to a .log file at an interval set by the customer, the temperature is given in Farenheit.
    the sensors are wireless, and there can be 600 sensors to one reciever unit. one reciever unit has to be connected to a compute if the reciever unit is to far away from the computer, the reciever could be fed with 24V, or it could be left withing distance to the computer and a relay transmitter could be placed between the transmitter and the reciever.
    I am already working with a programer in norway to make it so that we can get the temperature in C and so that the temperature will be not only stored in a local computer but also sent to a central cpu that will be backed uo every 24 hours.
    This is very interesting, and I'm only waiting for the software from the programer to make an onboard trial to see where the signal might be blocked doe to the steel bulkhead in a ship.
    -Cheers-
    Tycho
    GXMPLX's Avatar
    GXMPLX is offline Veteran Poster I am starting to push the Mods: of RE
    May 2008
    weston
    348
    Re: wireless temperature sensors
    Interesting!
    I show you mine if you show me yours!
    Probably these are not as wireless as yours, you connect them to a RS485 network then the network connects wireless to a TCP/IP network.
    They are good and not expensive.
    www.fullgauge.com
    Can you give me a link to your manufacturer?
    Aug 2005
    5,302
    Some of the process industries are beginning to use wireless transmitters. What sort of luck they have had I don't know.
    However, I think this technology offers some new dimensions in control networking and possibilities we have not thought of yet.
    Jan 2006
    Norway
    1,036
    4
    31
    Quote Originally Posted by GXMPLX View Post
    Interesting!
    www.fullgauge.com
    www.pointsix.com
    -Cheers-
    Tycho
    Jun 2007
    Norway
    74
    56
    Smile Re: wireless temperature sensors
    [quote=Tycho;113009]
    I have installed such a system hardware on several hospitals in Norway. In this system the transmitters takes up to 16channels each. Great system who has a software so you draw in all units as on the site so you can see the unit in a room who makes an alarm. You get a local alarm limit so the area people can decide what to do and over that an emergency level alarm limit which goes to security.The system send very well through heavy concreate walls. The new now is a server solution so you can get a separate access to the system from what place you want in the world. Hospitals does not like you to get access to their computers and that is the best for most of us. Be aware of the frequency. In most countries you have to get one allowed by some government people.
    Our one is free to use in hospitals also still near operation studios. It is makers also in Sweden and GB as I know Pedro
    GXMPLX's Avatar
    May 2008
    weston
    348
    Yeah, you guys made me feel embarrassed with my controls!
    Jan 2005
    Norfolk, U.K
    44
    65
    http://www.comarkltd.com/
    we have had these installed for a while at one of our sites, no problems that i know of.
    Oct 2003
    5,630
    34
    The well known European brand Eliwell has also a radio adapter available for remote monitoring like supermarkets.
    Tycho can need of course special demands due to the steel walls.
    Thinks Eliwell has repeaters also.
    ptkambdg's Avatar
    ptkambdg Guest
    Dear Tycho...
    It is intersting, I would be glad to have more information from you about this wireless temperature sensor
    Thanks & regards
    Aug 2007
    Sydney
    1,083
    23
    This technology has been availabe for more than ten years now. Trend and Siemens supply wirless sensors with battaries lasting up to 5 years. This technology saves a lot of labour on running cables and viable for about 8 sensors or more unless you have a differcult cable run. I'm still waiting for wireless power not just signals as of course Tesla innovated nearly 100 years ago - the blasted military govt keeps this tech from us (selfishly I think). If you want to pop your eyes open check out what John Hutchison is up to with LEVITATION http://www.americanantigravity.com/hutchison.html
    B AMAZED
    Italy
    15
    hi guys, i got the chance to use the Eliwell wireless solution,. different from other brand this tech is not use to remotize the sensor form the controller but it is used to connect the controller by a wireless network to the monitoring system. i used with eliwell software but as far as i know it is able to work with other software and controllers in case of modbus communication. I found it so efficient
    stserkan's Avatar
    stserkan Guest
    Can it be used in refrigeators?
    hcoles's Avatar
    hcoles Guest
    I see that Omega is selling wireless temp. sensors now. I need to check the other brands mentioned above.
  1. Replies: 12
    Last Post: 27-03-2011, 04:12 AM
  2. Superheat and Subcooling
    By Chunk in forum Fundamentals
    Last Post: 15-01-2011, 01:24 AM
  3. No. of temperature sensors required in cold storage?
    By dipankarmohanty in forum Technical Speculations
    Last Post: 14-03-2008, 07:45 AM
  4. TK basic micro-p features and functions
    By REEFER-TEK in forum Transport
    Last Post: 05-12-2007, 06:25 PM
  5. Article in ACH&R News
    By Gary in forum Fundamentals
    Last Post: 20-05-2003, 12:27 AM
