Results 1 to 10 of 10
Thread: Good techie needed for servicing
10-07-2008, 11:02 PM #1
Hi everyone I'm new here. I'm not an A/C tech, but chatting through the problems we've been having with our office A/C on another forum I've been referred here and it looks a friendly place.
After many years with the same company we've slowly been uncovering the poor service they've been giving us.
Here is the post I wrote on the other forum.
Hi guys, after calling out the A/C techies several times to diagnosis weak cooling on one of our office A/Cs I decided to take a look at it myself. First off it seemed to be making lots of noise and not moving much air around, so I switched it off and looked inside the evap fan. Blimey it was absolutely filthy.
Pic:
(not allowed as not enough posts)
Anyway, I managed to get through to Fujistu who explained to me how to get the fan assembly out and stripped and cleaned it up. along with the drain pan which was also clogged. The A/C now blows freezing cold but on occasions smells musty.
Looking at the evap it looks as though it could do with a good clean and deodourize. Do you guys know of any good products that would work well on a simple split unit? Bear in mind I can get directly at the evap coil. Would DWD be a good product to use or would you recommend something else?
Thanks for reading.
15-07-2008, 10:10 PM #2
15-07-2008, 11:00 PM #3
Re: Good techie needed for servicing
Thanks, PM is disabled for me I think, too few posts made so far, we're in Romford, that might be a bit far away for you to come if you're in Stafford.
I'm pretty sure once the fans have all been stripped down and the coils cleaned they're going to back to working order, but we'd really like someone thorough to service them when they're next due....6 months time possibly?
15-07-2008, 11:24 PM #4
15-07-2008, 11:39 PM #5
If you want to contact each other then download your V-card which will give your email address.
It is under 'Contact Info' in your User CP.Brian - Newton Abbot, Devon, UK
15-07-2008, 11:39 PM #6
Ahh OK thanks Brian..will do.
15-07-2008, 11:41 PM #7
15-07-2008, 11:56 PM #8
Well it saves making it too public and the spammers getting your emails etc
15-07-2008, 11:57 PM #9
email sent
15-07-2008, 11:58 PM #10
email sent
Paul
"KEEP IT COOL"
Autocascade refrigeration system: design verification needed
By DaBit in forum Technical SpeculationsReplies: 3Last Post: 07-02-2010, 07:48 AM -
Smart/As needed evap defrost?
By dkemper in forum FundamentalsReplies: 6Last Post: 27-10-2008, 07:25 PM -
Expert help needed fast..PLEASE
By jstch00tme in forum FundamentalsReplies: 26Last Post: 24-06-2008, 02:45 AM -
Australian split installers, some info needed
By paul_h in forum Air ConditioningReplies: 10Last Post: 20-05-2008, 03:40 PM -
good engineer
By Lc_shi in forum Chit Chat & Service StoriesReplies: 6Last Post: 28-09-2005, 12:12 PM
