Results 1 to 9 of 9
09-07-2008, 08:59 PM #1
copeland semi-hermetic compressors
Hi all
I am student and I am working in the compressor repair shop as trainee and I have got some general information about semi-hermetic compressors on the Copeland web site. I don't know how does the compressor test after repair?
And I want to know, are there any service and maintenance manuals about semi-hermetic compressors? Can anybody help me about that information? The compressor repair shop doesn’t give me any information about compressors also I live in Iran so I can't buy anything’s.
09-07-2008, 11:03 PM #2
Re: copeland semi-hermetic compressors
Aashvac/r, I have emailed a Carlyle compressor book to you.
I know that it is not Copeland but I am still looking.
[edit1] Try also downloading the Technical Reference Manual from here...
http://www.cmpcorp.com/downloads.asp
It shows exploded views of most semi-hermetics with parts identification.
[edit2]I have some older, assorted, Copeland documents which I could email, the zipped file size would be 26.5MB, can your systems accept a file this size?Last edited by Brian_UK; 09-07-2008 at 11:30 PM.
Brian - Torquay, Devon, UK
I have to stop saying "how stupid can you be?" to my co-workers.
They're starting to take it as a challenge...
BASIC MAINTENANCE. If it doesn't move and it should then use WD40. If it moves but it shouldn't then use Duct Tape.
09-07-2008, 11:36 PM #3
Aashvac/r
Below is the link to get Copeland's compressor performance calculator. You'll need to register before you can download it.
This tool allows you to check if the compressor is running within it's design criteria. But, only when it's installed in a complete refrigeration system. I don't know of any available information to test a compressor on the bench, not installed in a system.
There are service manuals available but I have not seen them in an electronic format. Once you register on the site you will see lots of information available.
http://www.emersonclimatecustomer.co....jsp&page=OPI2
10-07-2008, 03:00 AM #4
hi Brian_UK and powell
thanks a lot for your helps
Brian_UK my system can accept over that size.
now,i am looking some that
18-11-2009, 01:24 PM #5
hi brian can u please sent me the reference u are suggesting at the forum "[edit2]I have some older, assorted, Copeland documents which I could email, the zipped file size would be 26.5MB, can your systems accept a file this size?"
my mail is first.rain@hotmail.com
daniel
u can just inform me on my small maile daniel.chen@012.net.il that it was sent thanks in advance
18-11-2009, 08:05 PM #6
^^ Unfortunately I do not have access to some old files at the moment.
I had to replace my computer recently and need some different cables to allow me to reconnect my old disk drive that has the files on it.Brian - Torquay, Devon, UK
19-11-2009, 05:58 AM #7
Let me help Brian out while he's down.
Here's a link to Copeland and Tecumseh files. They're in the third collum from the left.
http://www.hvacrinfo.com/Last edited by powell; 19-11-2009 at 06:02 AM.
Thousands of HVACR manufacturers links! Visit: www.hvacrinfo.com
19-11-2009, 11:53 AM #8
OPERATING MANUALS OF BOCK SEMIS can be downloaded from www.bock.de
19-11-2009, 08:25 PM #9
Thanks for that Powell, I keep forgetting about that very useful site.
Compressors - screw or reciprocating?
By Josip in forum Industrial CompressorsReplies: 18Last Post: 27-01-2009, 11:36 PM -
Do we have some expert in replacing compressors
By Zahid in forum Air ConditioningReplies: 2Last Post: 01-07-2008, 07:59 AM -
DC Hermetic Compressors
By riggsby in forum Air ConditioningReplies: 1Last Post: 18-01-2008, 07:19 PM -
Oil changing on hermetic compressors.
By alexdouglas1969 in forum FundamentalsReplies: 8Last Post: 12-04-2007, 04:22 AM -
Part Wound Semi Hermetic Compressors
By bernard in forum ElectricalReplies: 9Last Post: 22-12-2005, 07:33 PM
To add to Frank's good description above. The balancing valve can be used to ensure the correct pressure drop is maintained which is transferred to flow rate, this can also compensate for difference...
Valves on FCU, AHU
