09-07-2008, 10:41 AM #1
very big problem with refrigerator comp.heat up low cooling in REF portion
hi every one
i've very big problem in my refrigerator
that in my refrigerator compressor heat up early and low cooling in refrigerator portion (not in freezer side)
and also compressor oil chock
please tell me reason and tell me
what can i do with existing 250 units (low cooling) what can i do with them
scrap them or any solution u have
what is the problem
our unit capcity is 340L
and we are using matsusita compressor 7.7cc
can problem in compressor or ???????
speacialy to BRAIN _UK, JOSIP, US ICEMAN AND ALL THE MEMBERS
PLEASE TELL ME WHAT WRONG WITH MY REFRIGERATOR
THANKS
JAHANGIR AHMAD KHAN
LAHORE PAKISTAN
More doors are opened with 'Please'then with keys (Hitler)
09-07-2008, 06:23 PM #2
Re: very big problem with refrigerator comp.heat up low cooling in REF portion
You didn't say what refrigerant they are using.
If its 134a, my guess is a blocked filter drier.
09-07-2008, 07:35 PM #3
Is the condenser inside the insulation? If this is so probably you have leaks and low refrigerant charge.
It is impossible to diagnose without more information. You need to install pinch off valves in one refrigerator and measure suction and discharge pressures and temperatures.
And refrigerant too as chemi-cool asked!
09-07-2008, 10:17 PM #4
Chem, sssshhhhttt, you weren't mentioend in the list of persons to help
09-07-2008, 10:29 PM #5
11-07-2008, 12:21 PM #6
hii every one
we are using R134a
and direct cool refrigerator
condensor outside of the refrigerator
this problem with 250 refrigerators not a single its came from enduser
more question please feel free to talk
thanks for urs reply
jahngir ahmad khan
lahore pakistanMore doors are opened with 'Please'then with keys (Hitler)
11-07-2008, 03:07 PM #7
You have 250 units with the same problem.
Definetly a design problem. Let's see, a refrigerant cooled compressor that's overheating.
1. undesized condenser
2. condenser not designed for high ambient (if applicable)
3. return gas temp too high
4. compression ratio too high
5. suction pressure too low
P.S. what does "compressor oil chock" refer too?
Some information on the aplication of suction gas/liquid line heat exchangers
By SteinarN in forum FundamentalsReplies: 5Last Post: 14-09-2009, 07:33 AM -
Hotpoint Future Fridge Cooling Problem
By Stoksey in forum DomesticReplies: 10Last Post: 26-01-2008, 07:42 PM -
Cooling tower evaporation, blowdown, makeup and cycles
By miltbeychok in forum IndustrialReplies: 5Last Post: 14-10-2005, 06:34 PM -
By miltbeychok in forum FundamentalsReplies: 0Last Post: 13-10-2005, 05:14 AM
