Thread: Cleaning fan blades
08-07-2008, 07:25 PM #1
Cleaning fan blades
If you need to clean a small shaded pole motor fanblade before refitting, spray some 'Easyfinish' (Advanced engineering) on it. It foams up and the grease just wipes off leaving a blade that looks as good as new.
Jon
08-07-2008, 11:36 PM #2
Re: Cleaning fan blades
Nice one, thank MS.
08-07-2008, 11:40 PM #3
Its worth the effort as a dirty fan blade will on average move between 50 and 60% of the air it is designed to move which obviously effects everything else in the system.
Ian
09-07-2008, 10:03 PM #4
That stuff is also good for getting grease spots off your customers nice new clean carpet, when you accidentally drop an sds drill bit on the floor.
Andy
11-08-2010, 05:56 PM #5
Heres a short vid of the stuff in action on a fifteen year old blade, works just as well on greasy take away blades too.
http://www.youtube.com/watch?v=RNU-4YjQ1d0
Jon
11-08-2010, 11:10 PM #6
That stuff could well be ideal for my motorcycle engine methinks.
11-08-2010, 11:24 PM #7
It'll need a good rinse with water as it makes the aluminium go a chemically if you leave it to dry on. Not a problem with fan blades though as you can't see em when they're whizzing round
Don't try that grease gobbler stuff though it'll take the paint off just like brake fluid does
Jon
air duct cleaning
By Lc_shi in forum New TechnologiesReplies: 10Last Post: 10-12-2008, 05:09 PM -
Cold store Evaporator cleaning
By hookster in forum System OptimizationReplies: 12Last Post: 22-07-2008, 04:04 PM -
Cleaning Compressors
By Chunk in forum Supermarket RefrigerationReplies: 21Last Post: 15-04-2008, 06:52 PM -
Vacuum pump cleaning and POE!
By The MG Pony in forum FundamentalsReplies: 8Last Post: 31-03-2007, 06:06 PM -
Cleaning suction strainers.
By Stuart Ginbey in forum Air ConditioningReplies: 6Last Post: 26-05-2004, 02:22 AM
