    3,856
    Cleaning fan blades
    If you need to clean a small shaded pole motor fanblade before refitting, spray some 'Easyfinish' (Advanced engineering) on it. It foams up and the grease just wipes off leaving a blade that looks as good as new.
    Jon
    11,025
    Re: Cleaning fan blades
    Nice one, thank MS.
    Nov 2006
    63
    392
    Its worth the effort as a dirty fan blade will on average move between 50 and 60% of the air it is designed to move which obviously effects everything else in the system.
    Ian
    May 2006
    Isle of Wight, Uk
    47
    424
    That stuff is also good for getting grease spots off your customers nice new clean carpet, when you accidentally drop an sds drill bit on the floor.
    Andy
    3,856
    Heres a short vid of the stuff in action on a fifteen year old blade, works just as well on greasy take away blades too.
    http://www.youtube.com/watch?v=RNU-4YjQ1d0
    Jon
    11,025
    That stuff could well be ideal for my motorcycle engine methinks.
    3,856
    It'll need a good rinse with water as it makes the aluminium go a chemically if you leave it to dry on. Not a problem with fan blades though as you can't see em when they're whizzing round
    Don't try that grease gobbler stuff though it'll take the paint off just like brake fluid does
    Jon
  1. air duct cleaning
    Last Post: 10-12-2008, 05:09 PM
  2. Cold store Evaporator cleaning
    By hookster in forum System Optimization
    Last Post: 22-07-2008, 04:04 PM
  3. Cleaning Compressors
    By Chunk in forum Supermarket Refrigeration
    Last Post: 15-04-2008, 06:52 PM
  4. Vacuum pump cleaning and POE!
    By The MG Pony in forum Fundamentals
    Last Post: 31-03-2007, 06:06 PM
  5. Cleaning suction strainers.
    By Stuart Ginbey in forum Air Conditioning
    Last Post: 26-05-2004, 02:22 AM
