Thread: Preesure Vessel
    Nov 2007
    India
    74
    Preesure Vessel
    What are criterea for calculating the thickness of ammonia high pressure receiver shell and dishend.
    Is only consider ASME code.
    Or storage capacity of ammonia / flow of ammonia / persons working there. Ammount of ammonia charge.
    raj
    Jan 2006
    Croatia
    68
    2,261
    31
    Re: Preesure Vessel
    Quote Originally Posted by Rajkumar View Post
    raj
    ... not too familiar with ASME codes, but I believe they covered everything....
    ... many years before I was working in factory manufactured pressure vessels and this is something I can remember now ...
    .... mainly thicknesses depend on many factors like .... pressure "P", diameter "D", volume "V", size and number of connections, material properties-different for normal or low temperatures application... there are a special equitations for calculation of static vessels .....
    ... then we have requirements for manufacturer certification, quality assurance, design, materials, manufacturing and testing ....
    .... not a simple manufacture procedure at all...
    Best regards, Josip
    India
    688
    Re: Preesure Vessel
    There is one book on heat exchanger design & that gives all the data. I shall get that name for you.
    Nebraska
    77
    Re: Preesure Vessel
    Yes ASME is the code.
    The temp/press is considered.
    To do these calculations by hand I used to be able to do 1/10 hr day.
    With Software...I did 5 before lunch depending on the openings.
    Codeware and many more are availeable Cost ..about $5-6k
    But what is time worth?
    Aug 2005
    5,302
    Re: Preesure Vessel
    Or storage capacity of ammonia / flow of ammonia / persons working there. Amount of ammonia charge.
    You need to design the vessel for what you want it to do. Size, volume, nozzles, etc. Once you have the geometry of the vessel, then you use the pressure vessel codes to design the thickness, welds, heads, etc.
    These are two separate design procedures.
  1. Do I need a chilled water buffer vessel
    By Consultant in forum Commercial
    Last Post: 02-03-2011, 09:40 AM
  2. vessel size calculation
    By hardy surya in forum NH3
    Last Post: 29-10-2008, 03:20 PM
  3. Replies: 0
    Last Post: 14-05-2008, 05:05 PM
  4. European Pressure Vessel Design standards
    By halacoque in forum Commercial
    Last Post: 17-03-2008, 09:32 PM
  5. Parker levels in ammonia systems
    By Friobernal in forum Industrial
    Last Post: 04-08-2005, 03:46 PM
