06-07-2008, 06:18 AM #1
Need Info on C-R170H5B compressor
I got a old air con that i stripped down and ive looked over the compressor head to toe for info regarding what gas it uses and how much horse power it is but cant find anything on the compressor or on the internet.On the compressor it says the basic info like its 50hz, uses 240v and the model number of C-R170H5B. Now im going to use this compressor to make a autocascade, so i really need to know the displacement. I realise most model numbers show the displacement of the compressor, but thats not always the case, and i think based on the size of the original unit its in the 2hp range so 170ml3 displacement cant be right. The only information i get typing in that model number on google is a pdf file which shows it's price of $2700.Any help is highly appreciated.
06-07-2008, 11:35 PM #2
Re: Need Info on C-R170H5B compressor
Hi Raadster, if you can give us details of the unit that you stripped down then we might be able to identify that compressor.
07-07-2008, 01:58 AM #3
All I know is that the compressor was removed from a domestic air con that was reverse cycle. The only info I can provide is whats marked on the compressor, which ive listed above. Well it also says made in japan on the compressor if that helps, i left that out since im sure thats kinda irrelavent.
08-07-2008, 03:56 AM #4
The aircon was a sanyo, but on the cover I recovered it didnt say anything else.
Compressor Technical info.
By Chunk in forum Technical SpeculationsReplies: 2Last Post: 03-05-2008, 09:27 PM -
SL/SB-400 Pump Down Procedures
By absolute-zero in forum TransportReplies: 1Last Post: 29-01-2008, 09:27 PM -
Tech info or direction to for data Mitsubishi RR120 220/240v rotary compressor
By eskimo2 in forum Technical SpeculationsReplies: 4Last Post: 04-01-2005, 04:04 AM -
Compressor pumping efficiency
By shogun7 in forum FundamentalsReplies: 0Last Post: 25-02-2004, 10:50 PM
