Results 1 to 11 of 11
Thread: Charging as a liquid or a gas
04-07-2008, 07:33 AM #1
Hey folks is there any documents detailing whether to charge as a gas or a liquid
Can R59 be charged both forms
Thanks in advance
04-07-2008, 12:43 PM #2
Re: Charging as a liquid or a gas
Charge everything as a liquid - then you can't go wrong!
Tony
04-07-2008, 03:44 PM #3
Never heard of R59. Are you sure this is the correct name?
Tony is right though, you can always charge in liquid phase but be careful to evaporate the liquid if you are charging to the low side, unless you do it in reasonable amounts and have a suction accumulator in between.
04-07-2008, 04:01 PM #4
Hi Hammy,
R59/R417A needs to be charged as a liquid.
Have a look here
http://refrigerants.dupont.com/Suva/.../isceon59.html
Jon
04-07-2008, 04:40 PM #5
Thanks! so R59 is indeed a wrong name!
05-07-2008, 05:19 PM #6
High glide refrigerant blends such as HFC R407C, HCFC R409A and other zeotropic
refrigerant blends (to a lesser extent HFC R410A and HFC R507) fractionate during
transfers of the blends from one container (e.g., tank or cylinder) to another
causing the composition of the blend to change. This change in composition can
make the product off specification, change it's performance and/or make the material hazardous.
All of the R4 series need to be charged as a liquid to stop this happening.The difference between genius and stupidity is that genius has its limits.
Marc
05-07-2008, 11:13 PM #7
... or charge full containers!
05-07-2008, 11:49 PM #8
09-07-2008, 09:15 PM #9
causing the composition of the blend to change.Tony
28-07-2008, 04:53 AM #10
04-08-2008, 02:15 PM #11
The best advice is;-
If the refrigerant begins with a capital R it is ASHRAE approved.
Then if the first number after the R is a 4, 5 or 6 it's a blend and should be liquid charged.
Superheat and Subcooling
By Chunk in forum FundamentalsReplies: 42Last Post: 15-01-2011, 01:24 AM -
Liquid charging through the suction side
By deu58 in forum FundamentalsReplies: 13Last Post: 02-07-2010, 05:23 AM -
Charging liquid through suction line?
By SloFuse in forum Trouble ShootingReplies: 15Last Post: 20-06-2010, 09:26 PM -
Parker levels in ammonia systems
By Friobernal in forum IndustrialReplies: 3Last Post: 04-08-2005, 03:46 PM
