    aprilia7's Avatar
    aprilia7 Guest
    Heating and ventilation systems questions
    Just wondering if anyone can help with these two questions?
    1.What are the correct operating ranges of heating and ventilation systems,to include temperature and pressure of secondry heating sources (air and water)?
    2.What are the typical building design temperatures,such as for offices,factories (light and heavy work),warehouses and canteens?
    Any help would be much appreciated
    Oct 2001
    Nottingham UK
    5,667
    Re: Heating and ventilation systems questions
    Quote Originally Posted by aprilia7 View Post
    Sounds like a college question to me and I daren't answer it as I got my wrist slapped last time
    Have you tried a little research in the library??
    (Apologies if it's not a college question )
    11,024
    1.What are the correct operating ranges of heating and ventilation systems,to include temperature and pressure of secondary heating sources (air and water)?
    1. There are no correct operating ranges that I know of. You need to supply details of the design requirements of the building being served.
    Is it an office, a factory or a science block?
    Temperatures will be to suit your system. As for pressures, who knows? If you install undersized ductwork then your pressures will be extremely high and your costs will escalate.
    2. You will find this information in the text books covering the subject.
    In the absence of the correct text books there is always Google to fall back on
  1. heating coil in front of duct unit
    By cruzeiros in forum Air Conditioning
    Last Post: 13-02-2006, 11:32 PM
