Results 1 to 11 of 11
    Mar 2008
    US
    74
    heat exchanger between subcooling and superheat line
    Does anyone use heat exchanger between subcooling line and superheat line? It works or not? I remember there is a discussion post about this in forum. But I couldnt find it now. Thanks.
    David
    Feb 2008
    Norway
    57
    446
    Re: heat exchanger between subcooling and superheat line
    GXMPLX's Avatar
    GXMPLX is offline Veteran Poster I am starting to push the Mods: of RE
    May 2008
    weston
    348
    Quote Originally Posted by SteinarN View Post
    TKS SteinarN, great post!
    You should add to it a discussion on useful and not useful superheat, because of the possitive effect a SG/LL HE would have to reduce energy loss in a suction line that can't improve insulation like the ones in trenches in old supermarkets.
    Mar 2006
    Merate (LC) - Italy
    2,549
    It works, but as most people due, irresponsibly increase superheat to increase subcooling as much as they can. This is the best way to have a high efficiency, quickly dying, compressor. It will suck rarefied, superheated vapour at high temperature, and the motor will soon burn.
    Feb 2008
    Norway
    57
    446
    Quote Originally Posted by NoNickName View Post
    I think this is way oversimplified. I agree it is not the best idea to install a SG/LL HE on a system running at -40C evaporating and 50C condensing. However there is many systems running at operating conditions where a SG/LL HE can be aplied with great success. If very high condensing is experienced only a short time every year, then a SG/LL HE can be combined with a demand cooling system for lowering the suction gas temperature those days ambient is very high.
    The efficiency of the compressor is also an important factor under these circumstances. An ineficcient compressor leads to even higher discharge temperatures than a more efficient compressor does.
    Mar 2006
    Merate (LC) - Italy
    2,549
    Agreed, but these days I've seen too many pirates, who simply downsize the compressor and gets the extraquid with a SG/LL HE, causing 25K subcooling and 40K superheating, with a discharge temperature in excess of 130-140°C.
    For example icecream makers of an important italian brand.
    Aug 2005
    5,302
    Agreed, but these days I've seen too many pirates,...
    Unfortunately, this is what the refrigeration business is becoming. A situation where owners (or accountants) are making business decisions on the lowest initial cost without any regard for equipment life.
    The lowest common denominator everyone sees is cost, because they don't understand the long term effects and usually don't want to listen to someone.
    GXMPLX's Avatar
    May 2008
    weston
    348
    I thought this happened only here! Good to know we are not alone!
    Mar 2008
    US
    74
    Thank you everyone. Great discussion. Let me digest them before I can make new comments. Thanks.
    Happy holiday!
    David
    Oct 2003
    5,630
    34
    Holiday you said??? What's a holiday??
    Mar 2008
    US
    74
    Peter, I think this long weekend is holiday. July 4.
  1. Superheat and Subcooling
    By Chunk in forum Fundamentals
    Last Post: 15-01-2011, 01:24 AM
  2. Benji
  3. Superheat and subcooling
    By marc5180 in forum Training
    Last Post: 08-10-2007, 09:21 PM
  4. Efficient Water-Source Condenser Design?
    By Enginerd in forum Fundamentals
    Last Post: 28-05-2007, 05:11 AM
