Results 1 to 10 of 10
Thread: r407/410 leak
    Feb 2007
    SIDE OF THE ROAD
    262
    r407/410 leak
    hi,
    if i have a leak on either of these refrigerant on a liquid line, would the blend be still intact and re-usable..?
    rgrds phil
    Feb 2007
    2,473
    Re: r407/410 leak
    Yes.
    Or Maybe No.
    Or it might.
    It all depends on who you are listening to.
    If it's only liquid that's escaped then I can't see how the mixture would have changed but we all take our chances and live with our decitions.
    Jan 2008
    Kent
    47
    Re: r407/410 leak
    I read that a topped-up R407C system would perform around 90% efficiency, even after multiple leaks - some academic study, I can't find it now unfortunately.
    Mar 2007
    Sheffield
    8
    Re: r407/410 leak
    If you have a leak on a system - anywhere - blended refrigerants will change their... er.. blend!
    In the case of R407c its made up of 3 different refrigerants which all boil off at different temperatures, therefore are in different molecular states and hence some will escape through the hole whilst larger molecules may be held.
    Recaim it man, fix it, pressure test it - it'll save you the headaches later.
    Mar 2006
    Lancashire
    1,859
    28
    Re: r407/410 leak
    I was taught that if the system had lost more than 15 or 20% of the total charge then it must all be reclaimed vacced out and then recharged with the correct amount.
    Marc
    TRASH101's Avatar
    TRASH101 is offline Veteran Poster I am starting to push the Mods: of RE
    Mar 2007
    394
    Re: r407/410 leak
    Listen to si he makes good sense
    If it is a leak on the liquid line the only time it is not going to noticabley alter the blend is if it is a big leak and that aint good either
    Mar 2007
    Warwickshire UK
    723
    Re: r407/410 leak
    On your system
    When the compressor stops & the pressure equalises ,,,, will the liquid line then still be 100% liquid ?
    After some refrigerant is lost & the system is running SOG will the liquid line still be 100% liquid ?
    With R407c you have to suspect that the system is not leaking an equal measure of the 3 which make the blend even if the leak is on the liquid line.
    So the possibilty is that you are left with an incorrect blend.
    As the high pressure refrigerants will tend to escape first ( R32 & R125 ) you could assume a high concentration of R134a left in the refrigerant in the system & you might notice the system running slightly lower discharge temp & pressure after topping up. ( after you have first fixed the leak )
    If the system has lost most of the refrigerant charge then whats left might be almost pure R134a.
    froidclim's Avatar
    froidclim Guest
    Re: r407/410 leak
    hello dear colegues
    concerning the leak of r407c i have a 2 questions
    1 what is the normal low pressure of r407c
    2 can we use the leak detector as for r134
    pls advise
    Mar 2006
    Lancashire
    1,859
    28
    Re: r407/410 leak
    1) I would expect to see around 4.5bar on the low side when running correctly but there are factors to consider.
    2) Yes you can use a leak detector on 134a.
    Marc
    GXMPLX's Avatar
    GXMPLX is offline Veteran Poster I am starting to push the Mods: of RE
    May 2008
    weston
    348
    Re: r407/410 leak
    It all depends where the leak is. If it is in places where the mixture is at right compositions, it won't affect the mixture, like liquid line and suction line.
    If the leat occurs in the midle of the evaporator or condenser it could affect composition.
    If the mixture is not at the right composition you will get some variable out or range, like discharge temperature or capacity.
    The only real way to tell is have a composition test on a sample of the mixture, and I've never done this.
    So to be en the safe side you better recover/recharge but you can first give a try.
    The leak detectors for HFCs need to be more sensible than HCFCs so you should check the manufacturer data.
  1. Leak detectors
    By Temprite in forum Tools and Calculators
    Last Post: 18-08-2010, 04:15 PM
  2. Evasive gas leak
    By Feeze in forum Technical Discussions
    Last Post: 18-08-2008, 07:22 AM
  3. Help!!! Shell and Tube Evap Leak
    By tommy Gun in forum Trouble Shooting
    Last Post: 22-07-2007, 12:45 PM
  4. Tiff 5000 leak detector
    By davidchesson in forum Tools and Calculators
    Last Post: 06-11-2006, 04:26 AM
  5. Can't find leak with UV Dye
    By jd_boggs in forum Transport
    Last Post: 16-09-2006, 06:22 PM
