Results 1 to 10 of 10
29-06-2008, 10:43 PM #1
About desing refrigeration system
Hello people....
I need information about desing of refrigeration system for maintenance and cooling tunnels or freezing, I would like to Know, How to select in correct form the different components of the system,
compressor, condensa, condenser, etc....
Some person has information or a Books about it....
I woul like to participate lost in the forum, but, My english is not good...
Thank you.
greetings
30-06-2008, 12:12 PM #2
Re: About desing refrigeration system
german,
Here is a link to the Heatcrafts manuals. These are great manuals to read but I have only seen them in English.
regards...............powell
http://www.heatcraftrpd.com/service/handbooks.asp
30-06-2008, 03:18 PM #3
Thank you very much Powell
I understand the Manuals, they are nice...
Thank you, again
Greetings
06-08-2008, 04:07 PM #4
pls i will like u to give an help line in other to be able to design an ice machine which would be a dry system and wont be more than 2 to 3 hours.
06-08-2008, 04:08 PM #5
any body can help me out
06-08-2008, 04:34 PM #6
Saludos german.
TEngo alguna info en medio magnetico que te puede servir.
06-08-2008, 09:13 PM #7
FEssyone, post your question in the right section, nobody will read it here.
What will be not more than 2 to 3hours?It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
07-08-2008, 05:06 AM #8
Hola sanvaltio
Disculpa por no haber respondido, no me llegan los avisos automaticos de respuesta de mis Post.
De que manera me podrias conpartir tus archivos?
Saludos y Gracias.
10-08-2008, 01:30 PM #9
Yo German,
can whe have it in plane englis to please ..?
thnx, Ice
27-12-2008, 06:38 PM #10
hi friends,
pls help me to tell about the selection criteria for single phase hermetic compressors selection for the desisred application of refrigerations.
regards
gulshan kumar
Leak Testing?
By Thana in forum Trouble ShootingReplies: 36Last Post: 31-08-2010, 02:57 PM -
Training about save energy in refrigeration system
By german in forum TrainingReplies: 4Last Post: 26-06-2008, 05:15 AM -
Thermal Efficiency of Refrigeration System
By hussain316 in forum Refrigeration BooksReplies: 5Last Post: 31-07-2007, 08:59 PM -
Water inside of ammoniac refrigeration system
By Nicolás Vera V. in forum NH3Replies: 14Last Post: 27-07-2006, 03:50 PM -
21st centry refrigeration system
By dan wong in forum Technical SpeculationsReplies: 21Last Post: 20-04-2002, 12:30 AM
