    panas's Avatar
    panas Guest
    Thermostat settings
    Hi!
    I think it is easy for you. What does it mean? (For K50 thermostat)
    Cold Out -27ºC
    Cold In -17ºC
    Warm In -12ºC
    And If for example I put number 6 ( from 7) on the thermostat settings how it should work?
    Thank you
    Jun 2008
    Grimsby
    7
    Re: Thermostat settings
    Ranco VF3, K50-P1117 is a similar thermostat.
    Cold out is the coldest setting the thermostat will cut out at -27degC (no 7 on your dial)
    Cold in (warm out) is the temperature the thermostat will cut in at if set at no 7. (-17deg.C) or the temperature it will cut out at on the warm setting (-17deg.C)
    Warm in is the highest temperature the thermostat will cut back in at no 1 setting. (-12 degc)
    Hope this help and i have explained it to you in simple terms.
    Jun 2008
    Grimsby
    7
    Answering the second part of your question
    On a no 6 setting, temp will work as follows
    Cut out = 17 + (27-17) x 6/7 = 25.6 deg.C
    Cut in = 12 + (17-12) x 6/7 = 16.3 deg.C
    Cut out will always be between -27 and -17 deg.C
    -27 no 7 & -17 no 1
    Cut in will always be between -17 deg.C and -12 deg.C
    -17 no 7 & -12 no 1
    The setting you chose will be a ratio of these settings as calculated above.
    cheers
    Mark Thomas
    All Seasons Refrigeration & Air Conditioning Ltd
    Oct 2003
    5,630
    34
    Mark, good post on a simple subject.
  1. Field settings
    By Vincentair in forum Fundamentals
    Last Post: 13-06-2009, 10:57 PM
  2. defrost thermostat closed failure
    By rkmoorthy in forum Trouble Shooting
    Last Post: 02-03-2008, 10:55 PM
  3. Change BRC1D528 for X10 Thermostat
    By creible in forum Air Conditioning
    Last Post: 07-01-2008, 09:35 PM
  4. Two Stage Thermostat for Heat pump
    By Franzfernando in forum Electrical
    Last Post: 02-11-2006, 12:20 PM
  5. Thermostat compatibility
    By Frusciante in forum Domestic
    Last Post: 10-04-2006, 11:43 PM
