Thread: Thermostat settings
28-06-2008, 08:28 AM #1
Thermostat settings
Hi!
I think it is easy for you. What does it mean? (For K50 thermostat)
Cold Out -27ºC
Cold In -17ºC
Warm In -12ºC
And If for example I put number 6 ( from 7) on the thermostat settings how it should work?
Thank you
28-06-2008, 10:00 AM #2
Re: Thermostat settings
Ranco VF3, K50-P1117 is a similar thermostat.
Cold out is the coldest setting the thermostat will cut out at -27degC (no 7 on your dial)
Cold in (warm out) is the temperature the thermostat will cut in at if set at no 7. (-17deg.C) or the temperature it will cut out at on the warm setting (-17deg.C)
Warm in is the highest temperature the thermostat will cut back in at no 1 setting. (-12 degc)
Hope this help and i have explained it to you in simple terms.
28-06-2008, 10:20 AM #3
Answering the second part of your question
On a no 6 setting, temp will work as follows
Cut out = 17 + (27-17) x 6/7 = 25.6 deg.C
Cut in = 12 + (17-12) x 6/7 = 16.3 deg.C
Cut out will always be between -27 and -17 deg.C
-27 no 7 & -17 no 1
Cut in will always be between -17 deg.C and -12 deg.C
-17 no 7 & -12 no 1
The setting you chose will be a ratio of these settings as calculated above.
cheers
Mark Thomas
All Seasons Refrigeration & Air Conditioning Ltd
29-06-2008, 08:00 AM #4
Mark, good post on a simple subject.
ThanksIt's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
Field settings
By Vincentair in forum FundamentalsReplies: 11Last Post: 13-06-2009, 10:57 PM -
defrost thermostat closed failure
By rkmoorthy in forum Trouble ShootingReplies: 2Last Post: 02-03-2008, 10:55 PM -
Change BRC1D528 for X10 Thermostat
By creible in forum Air ConditioningReplies: 5Last Post: 07-01-2008, 09:35 PM -
Two Stage Thermostat for Heat pump
By Franzfernando in forum ElectricalReplies: 3Last Post: 02-11-2006, 12:20 PM -
Thermostat compatibility
By Frusciante in forum DomesticReplies: 6Last Post: 10-04-2006, 11:43 PM
