Results 1 to 8 of 8
Thread: assab ultra 85 ???
27-06-2008, 07:47 PM #1
assab ultra 85 ???
anyone outhere look after any assab ultra 85 low temp units.... need to no the correct charge for 404a on first stage
05-07-2008, 05:11 PM #2
Re: assab ultra 85 ???
Doesn't look like it thebigcheese
Marc
09-07-2008, 05:17 PM #3
ino fs this thing is doing my nut in its been ongoing now for around 4 weeks
30-07-2008, 05:59 PM #4
Silly question but have you searched the net?
Marc
30-07-2008, 10:27 PM #5
got it sorted anyway had abit of guesstomation and its at -75 again so il leave it at that
18-02-2009, 07:29 PM #6
ah the old TAS cabinets!! they used to manufacture the same cabinet for peter swan.
there is nothing set in stone for these cabinets, the pressures are all different. they usually run about 5psi suction pressure on the first stage, 2nd stage is R170, watch out for waxing inside the capillary on first stage its a common problem, you will need to change the capillary. in fact maybe that is your problem
18-02-2009, 07:31 PM #7
just another point to add - they dont work too well on R404A, but R507 works ok.
24-02-2009, 09:10 PM #8
yea mate capillary was bad it blocked a spin drier within two hours... its been awile now anyway so fingers crossed
Ultra low Temp Refrigeration
By elmusasc in forum IndustrialReplies: 5Last Post: 31-07-2011, 07:00 PM -
Ultra sonic leak detection
By clivet in forum Tools and CalculatorsReplies: 18Last Post: 30-08-2010, 04:26 PM -
phoenix ultra career reefer need help
By mtbialik in forum Trouble ShootingReplies: 0Last Post: 27-05-2008, 06:17 AM -
help? Ultra low refrigeration help?
By Dalem554 in forum FundamentalsReplies: 11Last Post: 01-08-2007, 01:34 PM
