Results 1 to 11 of 11
    fdhealy's Avatar
    fdhealy Guest
    Cleaning the system after compressor burnout
    Do you need to remove and change the gad after a compressor burn out. The oil in the compressor passed a acid test.
    GXMPLX's Avatar
    GXMPLX is offline Veteran Poster I am starting to push the Mods: of RE
    May 2008
    weston
    348
    Re: Cleaning the system after compressor burnout
    "Gad" I donīt know.
    As for the refrigerant yes I would, just for supersticious behaviour.
    I definitely would recover it and clean the system thoroughly. Having clean oil does not mean you have a clean high side! At least from compressor to the filter dryer.
    Only if the refrigerant passed a composition test I would think in reusing it.
    Not having acidity in the oil may mean that the test failed or the burnout was so fast that crankcase oil was not that much affected. With open compressors this would be nonsense.
    Anyway a change in compressor will change this oil.
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by fdhealy View Post
    gad
    As service manager you should know answer to this question!
    You should recover refrigerant thru burn-out filter and then recharge it again thru burn-out filter, and it should be OK.
    Could be some concern about non-condensables in refrigerant.
    Of course, don't forget to put burn-out filter in liquid line and replace it after few hours of operation, with normal filter drier, if pressure drop at burn-out filter is OK. Also you should fit temporary suction line burn-out filter.
    Check this Copeland AE bulletin on Powell site for detailed procedure.
    Orlando's Avatar
    Orlando Guest
    i'm back would you please post more articles I had my refs compressor change ( no burned out but it doesn't give the maximun coolness must I charge it with more *****
    11,025
    Quote Originally Posted by Orlando View Post
    A year since your last post and this time with a confusing question, I think
    Oct 2010
    usa
    15
    @GXMPLX fdhealy typo'd it is gas the s and d are next to each other .
    and yes you would need to change the charge and flush the system otherwise you will ruin your new compressor.
    i am not sure if a recycler can clean the charge after a burn out or if they have to dispose of it.
    11,025
    ^^ Two year old thread and OP wasn't polite enough to respond.
    Dec 2009
    Spain
    45
    229
    15
    Quote Originally Posted by ejonesss View Post
    Any installer can clean the gas after a burn out if he has the correct method. So, he still can use the same amount of refrigerant after the cleaning process.
    Regards,
    Nando.
    Mar 2006
    Philippines
    35
    hello orlando, a lot of problem that can be associated to your inquiry, to begin with, is the compressor that was installed have the correct capacity to reject heat from its load?
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by kaelte_technik View Post
    I would say that rejecting heat is task of condenser. Compressor has task to pump refrigerant in sufficient amount that evaporator is utilized as constructor of system intentioned.
    Mar 2006
    Philippines
    35
    Yes nike 123, what I meant is the capacity of the system itself to do this work which includes the comp and condenser. My apology for the wrong use of word.
  1. Daikin fault codes
    By Chris2005 in forum Air Conditioning
    Last Post: 21-03-2012, 10:09 PM
  2. Leak Testing?
    By Thana in forum Trouble Shooting
    Last Post: 31-08-2010, 02:57 PM
  3. System Burn Out Troubleshooting
    By altaf22m in forum Technical Discussions
    Last Post: 07-05-2010, 09:24 AM
  4. Air conditioning system cleaning issue
    By Lc_shi in forum Legal-Business-Marketing
    Last Post: 24-08-2006, 03:03 PM
