Thread: Refrigerant Handling
24-06-2008, 10:01 PM #1
Iam An Engineer From The Uk, In 2001 I Obtained City And Guilds 207/208 Which Is The Refrigerant Handling Qualification. Does Anybody Know If I Need To Obtain Another Handling Qualification As I Do Not Know What Period Of Time 207/208 Runs For ?
24-06-2008, 10:34 PM #2
Re: Refrigerant Handling
As far as I know the C&G does not have an expiry date.
You may find however that the new F-Gas Regs may change all that.
There is a lot of info on the forum, try a search on F-Gas.Brian - Newton Abbot, Devon, UK
25-06-2008, 05:42 PM #3
Hi suctionheader,
I have just been reading the last service matters No.13 from the IOR service engineers section. What it has to say is that the current minimum legal requirement (a national refrigerant handling qualification City & Guilds 2078 or CITB refrigerant handling card) will be superseded by the new F gas refrigerant handling qualifictions City & Guilds 2079/CITB J11. And holding one of the current qualifications will allow you to work untill July 2011 by which time you must have taken the new F Gas Handlind qualification.
Hope this helps.
Arthur
Superheat and Subcooling
By Chunk in forum FundamentalsReplies: 42Last Post: 15-01-2011, 01:24 AM -
Refrigerant Handling Certification
By AYIBIBIO in forum Heat PumpsReplies: 2Last Post: 24-01-2008, 05:09 PM -
fun quiz
By Brian23 in forum New to REReplies: 6Last Post: 02-10-2007, 10:18 PM -
Refrigerant Handling course in uk
By C Bagtas in forum RefrigerantsReplies: 5Last Post: 19-11-2006, 09:22 PM -
Safe Refrigerant Handling certificate
By emiliano in forum RefrigerantsReplies: 8Last Post: 25-09-2006, 12:58 PM
