Thread: pierced ice cooler
24-06-2008, 04:30 PM #1
pierced ice cooler
Hi Guys,
i know this is going to sound really stupid, however I was trying to remove the ice from the sides of my ice cooler tray with a sharp knife, and i pierced the side. All of a sudden this gas(?!) came fizzing out. It had a really strong smell. I turned off the fridge at the mains.
Is this gas dangerous?? Have I broken my fridge or just the ice cooling tray at the top?
ANY advice would be appreciated!!!!
24-06-2008, 04:47 PM #2
Re: pierced ice cooler
Yes I would not breath it in and open doors to ventilate area. You have damaged your fridge as the aluminium coil you have pierced is very difficult to get a reliable gas leak free repair done.In my opinion repairs to the evaporator plate you have pierced are unsuccessful and would be a waste of money as they will not last, my advice is to get a new one.
Transvestites are men who like to eat, drink, and be Mary.
24-06-2008, 05:17 PM #3
24-06-2008, 09:45 PM #4
Hi there. I guess that you are not a fridge engineer and so if you could repair your damaged evaporator you still would not be able to recharge it. However if you do know someone that can recharge it with the correct gas you could try mending the damage with an epoxy such as Araldite. I have done this sucessfully several times over the years. It is important to ensure that the area is dry and any oil that escaped with the refrigerant is cleaned up. Roughen the surface with emry cloth and leave the Araldite at least 24 hours to cure. The drier will need changing and the system evacuating before recharging. Good luck
NH3 thermosiphon oil cooler
By cygbob in forum NH3Replies: 38Last Post: 22-06-2008, 05:12 PM -
TXV hunting in a walkin cooler
By dkemper in forum Trouble ShootingReplies: 9Last Post: 15-11-2007, 03:14 PM -
Walkin cooler
By masooda in forum Trouble ShootingReplies: 4Last Post: 09-02-2007, 04:57 PM -
Thermo-syphon Oil Cooler
By B.B. in forum IndustrialReplies: 5Last Post: 31-10-2005, 01:25 PM -
freezer is now a cooler
By superheat in forum CommercialReplies: 20Last Post: 18-03-2003, 12:32 PM
