Thread: question
22-06-2008, 10:11 PM #1
question
Hi to all
Anybody help with a college work question???
What does the term 'bumping clearance' mean and why do we have it??
22-06-2008, 10:18 PM #2
Re: question
Welcome Iceman 3000.
Usually known as "Bump Clearance"
The distance between the top (Crown) of the Piston and the underside of the Discharge valve plate
( WHICH IN THIS CASE FORMS THE CYLINDER HEAD).
Without some form of clearance there would be physical contact between the piston and the cylinder head.
This also allows for mechanical wear.
Cheers Grizzly
22-06-2008, 10:23 PM #3
Re: question
cheers grizzly...topman
23-06-2008, 01:32 AM #4
Re: question
However Iceman the distance is critical as too much reduces the efficiency of the compressor due to re-expansion of the gases in the cylinder which can seriously effect the swept volume of the compressor. Typically on a compressor that is set up correctly only about 60% of the cylinder volume is actually pumped through the discharge valve on each upward stroke. the larger the bump clearance the less gas is pumped. This is why screw compressors are more efficient than reciprocating compressors without taking into account the extra frictional losses.
Ian
23-06-2008, 02:23 AM #5
Re: question
Originally Posted by Pooh
The screw efficiency is only marginally greater at low to medium pressure ratios.
Recip's are not as bad as they are thought to be by screw salesmen.If all else fails, ask for help.
23-06-2008, 08:51 PM #6
Re: question
Also known as 'Clearance Volume' in compressor manufacturers data
23-06-2008, 08:54 PM #7
Re: question
I've moved this post to the correct section.
Iceman3000, please study the different sections before posting any more threads.
Refriferation cycle question
By ozmecheng in forum FundamentalsReplies: 32Last Post: 26-03-2008, 11:38 PM -
Hitachi RAC25NH5 question
By Yonas in forum Heat PumpsReplies: 11Last Post: 30-01-2008, 11:53 AM -
r134a question, calculating heat lost by refrigerant
By kamikazi929 in forum FundamentalsReplies: 0Last Post: 03-01-2008, 09:19 PM -
Newbie with a question
By AcidSlasher in forum FundamentalsReplies: 4Last Post: 07-03-2006, 12:20 PM -
Urgent, Kirchoff question
By Peter_1 in forum FundamentalsReplies: 4Last Post: 20-01-2004, 04:12 PM
