Results 1 to 10 of 10
22-06-2008, 05:48 PM #1
Suction Discharge Pressure Equalises After Cut Off
This compressor is a heavy duty chiller compressor(Copeland). This is having a temp. cut in- cut out settings of 8 to 12 degree celsius. When the compressor is running it is having a suction pressure of 60 psi and discharge pressure of 160 psi, but as soon as it cuts off discharge pressure equalises with the suction pressure and comes to 120 degree celsius. And the cooling side is also not that effective. It is just cooling only. What may be the problem?
Thanks and Regards
P.Philip
22-06-2008, 06:08 PM #2
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: Suction Discharge Pressure Equalises After Cut Off
Maybe compressor valves damaged.
22-06-2008, 06:21 PM #3
Compressor discharge valves are damaged.
22-06-2008, 06:30 PM #4
why you post the same threat TWICE
22-06-2008, 06:59 PM #5
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
22-06-2008, 07:25 PM #6
is he looking to salve his problem, or just harvesting posts
Ice
22-06-2008, 08:19 PM #7
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Many of newcomers do that. It is in human nature that someone wants that his "big problem" get most attention he could accomplish.
Especially, if he is 11 years old. We are spared of crying and rolling on the floor thanks to no direct optical and audio connection of this type of conversation!
Just joking!Last edited by nike123; 23-06-2008 at 12:11 AM.
23-06-2008, 12:07 AM #8
Most likely worn valves but could be the internal pressure relief valve ???
Try doing a pump down test to see what kind of vac it will pull.
23-06-2008, 10:49 AM #9
may be a faulty oil separator float or compressor unload solenoid valves ?
23-06-2008, 07:38 PM #10
What comes to 120 degrees celcius. Is it the discharge temperature? If it is and the compressor is reciprocating you could also have worn cylinders, pistons and/or piston rings. Maximum discharge temperature should be around 107 centigrade. Depending on system design could be normal that pressure equalizes but it should not happen fast. If you specify compressor model, refrigerant and media temperature of both condenser and evaporator maybe we could use the pressures you mentioned for something useful.
Superheat and Subcooling
By Chunk in forum FundamentalsReplies: 42Last Post: 15-01-2011, 01:24 AM -
Benji
By benji in forum Trouble ShootingReplies: 29Last Post: 30-01-2008, 01:25 PM -
cooling &freezing comp.
By afeef in forum Industrial CompressorsReplies: 25Last Post: 15-12-2006, 09:29 PM -
Suction pressure problems on TS units at low ambient temps
By nova in forum TransportReplies: 10Last Post: 18-03-2006, 07:35 PM
