Results 1 to 10 of 10
    rxstevan's Avatar
    rxstevan Guest
    Convert ac condenser to geothermal?
    I have had the unfortunate experience of the theft of my home ac condenser coils, just the coils. They left the guts in apparently good condition. It is a 2 ton unit and my house is less than 1000sf
    Would it be possible just bury the copper line around the perimeter(350ft) of my house/yard, and use the condenser as is.
    I have read about the ph level being possibly being a problem, and have yet test the soil.
    What would be the limiting factor? What do the geothermal units have that is different?
    I have basic knowlege of how the system works, and in my younger days, have been a fibergalss duct installer for 4 yrs with equipment sets (not start ups). Also redone my auto ac with a parallel flow condenser with great success. I do have a couple friends to help with the more technical aspect if it is possible.
    Sorry if this has been asked before, I did a search to no avail.
    Thanks.
    rxstevan's Avatar
    rxstevan Guest
    Re: Convert ac condenser to geothermal?
    This is in Florida, the soil temp is around 75ish, I think.
    Somerset
    69
    4,697
    Quote Originally Posted by rxstevan View Post
    Thanks.
    Welcome rxstevan.
    Others with more knowledge on this subject may prove me wrong.
    But the basic purpose of a Condensor is to give off heat.
    Converting the hot refrigerant gasses back into a liquid.
    As I understand it a geothermal system uses the ground as a heat source.
    Therfore what you are proposing could not work.
    Cheers Grizzly
    Split Croatia
    57
    6,151
    36
    Welcome rxstevan.
    Cheers Grizzly
    Grizly, geothermal heat pumps use its ground loop as condenser in cooling mode.
    Look here
    Somerset
    69
    4,697
    Look here
    Thanks Nike.
    Always something new to learn.
    And I am not to old to do so yet!
    That's exactly why my answer was cautious.
    Once again thanks.
    Oct 2006
    1,843
    21
    You could do it if you wanted but there would be a few things you need to take into consideration.
    The copper tube placed in the ground must be coated in plastic to stop corrosion. the lenght and duty must be callculated to esure it is long enough, too short and the thing will not condense. Too, too long and the refrigerant will over condense.
    It is possible do achieve, there are a lot of direct expansion heat pumps out there that do this (with the evap) so it is do-able.
    taz.
    jdstoke's Avatar
    jdstoke Guest
    A Geothermal system does not use a refrigerant. It utilizes water or antifreeze in a closed loop system.
    Apr 2006
    41
    1,620
    Quote Originally Posted by jdstoke View Post
    Read your history my friend, they where the first ones out there where the copper directly acted, this was phased out due tot he high risk of refrigerant release, that is when they started using water collectors rather then Dx.
    @OP
    Get your self a water to refrigerant heat exchanger, burry the plastic pipe down to 4-5 feet and as much of it you can! then you get a speed controller and a pump.
    Now you can balance the system with the flow rate and have reserv capacity!
    rxstevan's Avatar
    rxstevan Guest
    Thanks.
    Yes, I later found that 350-500 ft of burried pipe per ton is required, copper would be too expensive.
    I also have a small yard, but I read that a slinky type layout of the inground tubing may work.
    Apr 2006
    41
    1,620
    Just use a plastic tube collector and then a coaxial Hx in the unit.
  1. Superheat and Subcooling
    By Chunk in forum Fundamentals
    Last Post: 15-01-2011, 01:24 AM
  2. Plate Heat Exchagers - Condenser
    By Billy Ray in forum Technical Discussions
    Last Post: 11-05-2008, 06:16 PM
  3. method to design air cooled condenser
    By abbasi in forum New Technologies
    Last Post: 12-02-2008, 08:34 AM
  4. Optimum condenser fan speed
    By star882 in forum Fundamentals
    Last Post: 27-02-2006, 01:50 AM
  5. Cooling condenser of split with condensate from evaporator
    By smileypete in forum Air Conditioning
    Last Post: 10-07-2005, 08:21 AM
